RV.Net Open Roads Forum: Towing: Fastway E2 hitch Set up confirmation
Search only in Towing
Open Roads Forum  >  Towing
 > Fastway E2 hitch Set up confirmation
tim and amy
Beaverton Oregon
Posted: 04/30/12 09:31pm Link  |  Print  |  Notify Moderator
I have a couple questions for those who have used the E2 or 4 Point WD from Progress.
1. When setting up the hitch to not only get proper height and WD it may require using the lifting tool to get the bars onto the L brackets.
What is your method of removing the bar from the L bracket?
My premeasurements were
Unloaded
FR 38"
R 39.5
Loaded without WD
R 38 3/16"
Loaded with WD
FR 38"
R 39 1/8
According to the manual this is in the range required.
Any experiances with the E2 or things to watch out for?
Side wind or trucks?
Rutted freeway?
2012 Kodiak 300BHSL Ultimate with Fall Edition Package
2003 Ford Excursion V10
sdbounderdiesel
San Diego
Posted: 04/30/12 10:53pm Link  |  Print  |  Notify Moderator
I just recently installed an Equalizer Hitch w/4pt sway control to tow an enclosed car trailer behind my MH. First tow was about 1000 miles with no problems whatsoever. Strong crosswinds or tight maneuvering were not a problem. I haven't had to use the lifting tool at all to install or remove the WD bars. Using the jack stand to raise the hitch up fairly high seems to take most of the load off the WD bars so you can pretty easily slide them on or slide them off. Note: the jack stand by itself is not sufficiently long to raise the hitch high enough to take the load off the bars. Most people seem just put a few blocks of wood underneath the jack to give it the extra height. I bought a very handy device that seems to work very well. It is red plastic about 18 inches tall and kind of looks like a traffic cone. You just put it under the jack stand and crank it up. Its strong enough to handle quite a bit of tongue weight. I like it cause its very light and stores easily. Good luck with your hitch.
Allegheny N F Camper
Pennsylvania
Posted: 05/02/12 09:54am Link  |  Print  |  Notify Moderator
Chuck&Gail wrote:
I threw the snap handle away years ago. Buy an electric tongue jack and use it to raise TT/TV up until you can put the bars on and off by hand.
I've never use that hook up tool. I use the tongue jack. 7years and two different TTs this method has never failed me and not useing tool means one less thing I need to carry and worry about loseing.
Chuck&Gail
In the Colorado Mountains
Posted: 05/01/12 03:52pm Link  |  Print  |  Notify Moderator
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
BarneyS
S.E. Lower Michigan
Posted: 05/01/12 07:26am Link  |  Print  |  Notify Moderator
Hook up your trailer and then raise the trailer/truck combination with the tongue jack until you can put the bars on. The higher you raise it the easier it is to put on or take off the bars.
I think that sdbounderdiesel is talking about one of these. I use one also and it works great!
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
