RV.Net Open Roads Forum: Tech Issues: No Water!
 > No Water!
paulcardoza
Southeastern Massachusetts
Posted: 05/01/12 06:11am Link  |  Print  |  Notify Moderator
Hi All,
While taking a shower this morning, the water in the coach simply stopped flowing, instantly, as if someone had shut it off at the spigot. I turned on the water pump and using the onboard water, there was no problem.
Afterward, I went outside and there's plenty of water pressure (regulator set at 60psi). There is just no flow, like there is a blockage. Even if I flip the valve to fill the tank, no flow. I have a screen at the regulator which is clean, so I'd be surprised of there was a large blockage in the line after the city water connection.
I removed both filter elements, which were only 30 days old, and no difference. It seems like the problem is right after the city connection.
If anyone has any ideas what I can do to troubleshoot this, I would be most appreciative. It looks like a big job to disassemble the connection on my rig.
2003 Monaco Executive M43 DS2
Thanks!
Paul Cardoza
Currently in Foxboro, MA
Paul & Sandra
New Bedford, MA
fla-gypsy
North Florida
Posted: 05/01/12 06:18am Link  |  Print  |  Notify Moderator
Now thats just weird. I am following this one to see what the solution is. Do you have a check valve in the regulator? They can fail.
dqdick
Council Grove, KS
Posted: 05/01/12 06:29am Link  |  Print  |  Notify Moderator
That would be my thought also. If there is a back flow preventer in your system that would be where I would look first.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
five'er
Canada
Posted: 05/01/12 06:30am Link  |  Print  |  Notify Moderator
Did you try it without the regulator? Are you sure no one is playing games and flipped a switch or bypassed something by mistake? How cold was it where you were last night? Any chance anything froze?
Dick_B
Palos Heights, IL USA
Posted: 05/01/12 06:32am Link  |  Print  |  Notify Moderator
If I understand this problem all is well until you get to the RV. There should be a check valve just inside the RV inlet that prevents water from the RV going out backwards into the campground system and possibly contaminating it.
It's going to be lots of fun getting to it so you might wait for a few more responses. If that is the problem I would replace it with a brass model instead of plastic.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
sljkansas
Miami Co. Kansas
Posted: 05/01/12 06:39am Link  |  Print  |  Notify Moderator
I had that happen and it was the regulator.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
paulcardoza
Posted: 05/01/12 06:42am Link  |  Print  |  Notify Moderator
This is my fear, given the fact that flipping the tank fill valve doesn't work either....... Sounds like a fun evening after work tonite..... :-(((
zigzagrv
Nazareth, PA
Posted: 05/01/12 06:44am Link  |  Print  |  Notify Moderator
Ditto the regulator. They do go bad.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
'95 Tracker toad
Bucky Badger
Madison, WI
Posted: 05/01/12 06:46am Link  |  Print  |  Notify Moderator
Did you disconnect the hose from the RV and have pressure? Remove the regulator and see it it works....Hook the hose right to the rv
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Jim Shoe
Amelia, OH
Posted: 05/01/12 06:56am Link  |  Print  |  Notify Moderator
Check the individual pieces. Unhook the hose and regulator from the tap and RV. If water flows from the tap, then add the regulator and try again. If you still get flow, remove the regulator and hook the hose directly to the tap. If you still get flow, the problem is in the RV.
Retired and visiting as much of this beautiful country as I can.
 > No Water!
