RV.Net Open Roads Forum: Tow Vehicles: High Idle on 6.4 PSD
Search only in Tow Vehicles
 > High Idle on 6.4 PSD
Papasmurf10
Monrovia,MD USA
Posted: 05/01/12 07:01am Link  |  Print  |  Notify Moderator
If you have the uplift switches in your 6.4 PSD Ford and want to have a high idle switch here are the instructions:
Just pop off the plastic cover under the steering wheel, find the green/yellow wire in the large bundle of wires just above the Ebrake (they are bundled together and all have a black heat shrink looking end on them) then right above that bundle you'll see another group of 4 wires, I forgot the colors, but there is a solid brown one in that group (the brown one is for upfitter switch #4). Just make a jumper wire about 3 or 4 inches long and connect the green/yellow to the brown wire. It works! The E-brake has to be set and the transmission in PARK. Mine revs up to about 1200 RPM. If you touch the brake pedal, it will cancell it out.
I did it and I know nothing mechanical. It is suggested to turn on high idle if you idle for more than 10 minutes to maintain the proper temperature
2008 Ford F-350 Laredo
2009 Montana 1465
five'er
Canada
Posted: 05/01/12 07:59am Link  |  Print  |  Notify Moderator
interesting, did you find these instructions somewhere? Can you post the source? In my 06 CTD the dealer did this for me by programing the computer. I could then use the cruise control to adjust the RPM. Basically, turn on cruise and idle up by selecting the accel. This is how it's done in class 8 highway tractors.
Capt Skup
Southern Maryland/Nantucket
Posted: 05/01/12 08:00am Link  |  Print  |  Notify Moderator
Here is the SVE Bulletin that covers this subject from Ford. I hooked up both the 1200 RPM idle for PTO operation and the 900 RPM idle for battery charging back in 2007. Took all of 30 minutes to complete, nice on a cold day.
http://api.viglink.com/api/click?format=........162.pdf&jsonp=vglnk_jsonp_13358807067613
Also here are a few pictures looking up under the dash at the wires needed. A good light source is handy to find the wires that are bundled up.
* This post was edited 05/01/12 08:13am by Capt Skup *
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
F-450 Lariat 4x4
Honda Odyssey EX-L
SunlineF281SR
SeaRay 240 Sundeck
http://community.webshots.com/user/CaptSkup?vhost=community
davisenvy
Franklin, NC
Posted: 05/01/12 08:05am Link  |  Print  |  Notify Moderator
My 07 Dmax has an automatic or manual high idle. It comes on below 40 degrees.
2007 GMC Sierra Classic 2500HD SLT,4x4,Crew, Duramax
2011 Keystone Sprinter 323bhs
Capt Skup
Posted: 05/01/12 08:10am Link  |  Print  |  Notify Moderator
Good video for 6.0 Powerstroke for high idle set up.
http://www.youtube.com/watch?v=fmSNmPMtvcc
Turtle n Peeps
California
Posted: 05/01/12 08:53am Link  |  Print  |  Notify Moderator
I always thought the 6.4's you could bring the idle up to where you wanted it and hit the cruise control and it would hold?
outside the fire"
Papasmurf10
Monrovia,MD USA
Posted: 05/02/12 12:39pm Link  |  Print  |  Notify Moderator
Here is the forum where I got the info. This is the 6.4 but they have others for the other engines;
http://www.ford-trucks.com/forums/forum169/
swebber
Brunswick , MD
Posted: 05/01/12 08:57am Link  |  Print  |  Notify Moderator
I set up my 6.0 PSD for high idle. Was quite easy.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
