RV.Net Open Roads Forum: Tow Vehicles: F150 Too Small for 32' Trailer?
Search only in Tow Vehicles
 > F150 Too Small for 32' Trailer?
Quazi02
Posted: 05/01/12 08:31am Link  |  Print  |  Notify Moderator
I am interested in getting a Keystone Springdale Travel Trailer that is 32' long and weighs around 7,000 lbs.
I have a 2010 Super crew F150 with the 5.4L V8. The specs say that the truck can tow up to 8,500 lbs, but I am concerned with how the truck with handle a trailer of this size.
I plan to drive on the interstate a lot and I heard that the F150 frame is flexible and not stiff enough to keep the trailer in line on the interstate and that a F250 would be better for a trailer of this size.
Does anyone have any input on this and does anyone have a suggestion on a safe trailer weight and length for interstate driving?
imadtchmn
Macon, GA
Posted: 05/01/12 08:36am Link  |  Print  |  Notify Moderator
I had a coachmen that was the same size and weight as yours and pulled it with a 98 Expedition with the 5.4 and it pulled fine. You just have to have it set up right, meaning having the trailer level and the proper weight on the distribution hitch. I never did use any sway bar and never had any issues.
1998 Chevy 6.5 TB Dually
2001 Dutchmen ES33
DH George
DW Sherry
Dog Trinket
Rv with Style
downtheroad
Pacific Northwest
Posted: 05/01/12 08:46am Link  |  Print  |  Notify Moderator
First...what is the "weighs around 7,000 lbs?"
Is that the dry weight or the trip ready loaded weight?
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
therink
Rochester
Posted: 05/01/12 08:49am Link  |  Print  |  Notify Moderator
Also, what axle ratio do you have?
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
NewsW
US
Posted: 05/01/12 08:57am Link  |  Print  |  Notify Moderator
There are spec for weight and maximum frontal area.
Quazi02
Posted: 05/01/12 09:08am Link  |  Print  |  Notify Moderator
The 7,000 lbs is the dry weight and the truck has a 3.15 axle ratio.
tekman741
Gardner, Ma
Posted: 05/01/12 09:29am Link  |  Print  |  Notify Moderator
I have a springdale 296bh I went out and bought a used 04 chevy 3500 6 litre here's my opinion the 296 I picked up from the dealer last weekend was empty except propane Dry Weight lbs 6925, probably more like 7100. The frame of the 3500 took it on like nothing but the engine I felt a little, not a lot, was under powered. Granted it's a 4 spd tranny with tow haul and not one of them thar newer 6 spd tranny's. just personal experience. I now want a diesel.
04 chevy k3500 8'bed 6.0l gasser 4:10
2009 Keystone Springdale 296bhssr
M GO BLUE
Southgate, MI
Posted: 05/01/12 09:34am Link  |  Print  |  Notify Moderator
Can it tow that trailer? Sure
Can it tow it safely? NO
Too much length of the trailer and the weight is suspect...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Desert Captain
Tucson
Posted: 05/01/12 09:45am Link  |  Print  |  Notify Moderator
More than likely your rear end is 3:55, fairly common on F-150's (I have one) and in and of itself poses no major problem. Short answer is that the trailer is way to much for your truck. The first problem is payload or the lack thereof. Your truck probably has no more than 1500# of payload capacity and your 7000# dry trailer will have a GVWR of around 8500# (probably more). This will give you a tongue weight of around 1100#. Add in the weight of your WDH and you will only have a couple of hundred pounds left for you the family and all your stuff. Bottom line you will exceed the trucks GVWR which is never a good idea.
Second you likely exceed the GCWR which I'm thinking will be around 14,000#. The truck will be nearly 6000# + the 8500# (+) TT. Third you are right at and will probably be over your trucks tow capacity as the 7000# trailer will likely be at least 8500# and fully loaded likely more.
The 5.4L will pull it but it won't be fun, particularly safe or legal. 32' of trailer behind an F-150 is a lot of windage to go along with all the weight. IMHO: A 3/4 ton would be a far better choice. Good Luck!
smkettner
Posted: 05/01/12 09:49am Link  |  Print  |  Notify Moderator
Keep the trailer GVWR inside the tow rating for best results.
Skip the 250 and get 350srw.
675 watts solar
