RV.Net Open Roads Forum: Travel Trailers: Water Spewing from inlet valve
 > Water Spewing from inlet valve
canoe on top
Denver, CO, US
Posted: 05/01/12 06:59pm Link  |  Print  |  Notify Moderator
Sometimes the check valve just gets caught sideways. Pull the screen and poke the little plastic rod you see. If the O ring hasn't moved out of the groove, it will, often just pop back in place. If that doesn't work, you can pull the valve out and reset the O ring in the groove and put it back together. It's just a little, plastic, spring loaded, one way valve. A plug will get you by in the mean time. Even when the valve works, as mentioned, a plug is a good idea to keep dirt out.
CavemanCharlie
Storden,MN
Posted: 05/01/12 07:21pm Link  |  Print  |  Notify Moderator
Poke at the check valve, AND, buy a plug. Make sure when you screw in the plug that the rubber o ring is in place of the plug will not seat tight and it will still leak.
