RV.Net Open Roads Forum: Travel Trailers: Lifting my trailer
 > Lifting my trailer
tzclark
Chilliwack
Posted: 05/01/12 09:46am Link  |  Print  |  Notify Moderator
I was wondering if the common way to get your trailer a little higher was to flip your axles to the other side of the leaf? The reason I ask is because I am constantly scrapping my rear jacks. I am towing the trailer level so that's not the issue.
I'd rather be in a boat with a drink on the rocks, then in the drink with a boat on the rocks!
Bucky Badger
Madison, WI
Posted: 05/01/12 09:49am Link  |  Print  |  Notify Moderator
We did ours and love it...we had to build an extra step to get into the tt..the 1st step was to high for us
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
tzclark
Chilliwack
Posted: 05/01/12 10:28am Link  |  Print  |  Notify Moderator
Do you just use blocks under your jacks then?
pcines
So cal
Posted: 05/01/12 11:00am Link  |  Print  |  Notify Moderator
I use these brackets called saveajack. They are a quick release to make your scissor stabilizing jacks removable.
I just slide my jacks off when in transit. Easy to use. Love them.
I didnt want to flip my axles because it would have voided warranty
WyoTraveler
Northwest, Wyoming
Posted: 05/01/12 01:49pm Link  |  Print  |  Notify Moderator
The trailer hitch on my MH used to bottom out a lot when I pulled out of gas stations into the roadway. Never gave it much thought but I guess rear stabilizing jacks on TTs probably get pretty close to the ground when exiting those steep ramps onto the roadway.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
Bucky Badger
Madison, WI
Posted: 05/01/12 12:26pm Link  |  Print  |  Notify Moderator
Yeah, 6x6x12 work great
LIKE2BUILD
Mt. Zion, IL
Posted: 05/01/12 01:53pm Link  |  Print  |  Notify Moderator
Just purchase 2 of the Dexter Axle Flip Kits and install them.
If you are not aware, you don't physically "FLIP" the axle. You simply lift the trailer, remove the leaf springs, and install new spring seats on the top of the axle tube. If you were to flip the axle over it would cause two problems. 1) The designed arch in the axle would be upside down and cause flex problems. 2) Your brakes would not work properly.
KJ
'02 Jayco Qwest 324G
'04 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1 | Eaton Posi-Trac
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
2000 Crownline 205BR
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (12, 6, & 4)
1 forgiving wife!!!
wapitichaser
Parker, Colorado
Posted: 05/01/12 02:11pm Link  |  Print  |  Notify Moderator
I welded new perches on my axles and put the axles under the springs. Very common practice here in Colorado. Cost about $40 and about 2 hours to do. I was able to upgrade to 15" wheels from 14" wheels and install larger tires. I gained a total of 6 1/4" with the axle flip and bigger tires. Makes traveling less stressful.
tzclark
Chilliwack
Posted: 05/01/12 02:25pm Link  |  Print  |  Notify Moderator
My trailer has perches welded from factory on top and bottom, should make the task fairly easy.
vermont_blue
Colorado
Posted: 05/01/12 10:34pm Link  |  Print  |  Notify Moderator
Is there a tendency for the trailer to sway more when you lift it?
