rvert10
Utah
I've been looking for posts of Ford, Chevy and Dodge owners about emission problems. My reason is this: do all manufactures have the same problems or things just happen and because I just had a failure or clogged DPF and EGR on My 08 6.7L 3500 at 31k miles all of the driving is interstate (most of it) is there a common thread in the big three. Any takers on this question?
08 Dodge Mega Cab DRW,6spd auto, Exhaust break, 8'bed conversion (Best mistake I've made)
35' Teton Home Experience 3 slides, its not a trailer its a home
5500 watt generator
and a beautiful Co-piolet
45Ricochet
North Idaho
Yours should have fallin off by now Especially since your's has the conversion already.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
rvert10
Utah
45Ricochet wrote: Yours should have fallin off by now  Especially since your's has the conversion already.
I take that as a Yes.
Wills250psd
walnutcove NC
I dont have a clue what your talking about.
mr. ed
Madison, SD (but usually elsewhere)
What he's saying is that you can remove the emissions equipment using kits that are available (at your own risk, of course. It's technically illegal). I'm constantly tempted to "lose" the stuff in my 07.5 Dodge RAM but the legality issue holds me back. Anyway, I'm not having much problem with the emissions now. A few years ago it was a different story but since the J35 recall all's been fairly good lately.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
summithmk
butt#$%$ egypt, NV
rvert10 wrote: I've been looking for posts of Ford, Chevy and Dodge owners about emission problems. My reason is this: do all manufactures have the same problems or things just happen and because I just had a failure or clogged DPF and EGR on My 08 6.7L 3500 at 31k miles all of the driving is interstate (most of it) is there a common thread in the big three. Any takers on this question?
They all have emissions problems some more than others, take a look at cumminsforum.com you're not the only one with problems. My 2010 has been free of emission problems just gets **** fuel mileage due to regens.
45Ricochet
North Idaho
Wills250psd wrote: I dont have a clue what your talking about.
LOL
Just keep the parts, they are expensive to replace come selling time
Paul Clancy
BC Canada
All manufacturers may have an emissions failure at one time or another - but not all trucks will have a failure. My 09 has been flawless. Regen when towing is undetectible. The 07.5 - 2010 gm trucks seem to have the fewest issues, there were problems when def was added in 2011 but that seems to be corrected now. Emissions is another system that can fail but for me I value the no diesel smell so I'm alright with it because I view it as a desirable feature (crazy huh?). Rolling coal trucks I find very offensive.
edited 05/02/12 05:24am by Paul Clancy *
carringb
Corvallis, OR
Both of our 6.7L Cummins (one Dodge, one Sterling) have chronic emissions-related issues. Some just a nuisance (frequent check engine lights, periodic loss of power), some are more than a nuisance (7-MPG average and excess fuel in the engine oil)
Ford kind of learned about EGR problems the hard way on the 6.0 PSD. But, the 6.4L PSD also gets terrible fuel economy.
ALL of the new diesels require much more diligent maintenance. Topping of your antifreeze with standard green stuff can land you with a cracked EGR cooler. This was a common cause for blown head gaskets on the Ford 6.0, and increasingly seems to crop up on the Cummins 6.7L.
So.... stick with OEM specs on everything.
As for letting your emissions equipment fall off.... Be sure you understand all the potential consequences of that. This could result in a cancellation of the warranty (YES, that is a written term within the warranty contract), to potential EPA fines, which can be steep if you are a business owner, as these fines are based on business revenues. Private owners probably won't face fines, but you could face an inability to register the vehicle in an emissions-check area.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
