RV.Net Open Roads Forum: Toy Haulers: On our 3rd Fresh Water tank!
Search only in Toy Haulers
 > On our 3rd Fresh Water tank!
MoandJo
Tucson, AZ
Posted: 05/01/12 03:54pm Link  |  Print  |  Notify Moderator
Anyone have a 2008 Thor Vortex Toyhauler with a 100gal fresh water holding tank?
We have a 21fk very small toyhauler, but our fresh water tank seems to develope a crack right where the baffle is in one of the corners by the drain end of the tank.....no, we dont travel with water in it and no, we drain it completely for winter. Living here in Tucson, AZ we really dont have a freezing problem anyhow...
Thank god we got the first one replaced under warranty, the second one we just replaced last month under our extended warranty.
It really seems to be a defect, just wondering if anyone else is having the same issue...the dealer where I bought it and have it repaired wont do any customizing....they said it would void the warranty!
SWD
Land of Living Skies
Posted: 05/01/12 06:28pm Link  |  Print  |  Notify Moderator
It must be flexing that eventually it cracks. Anyway you could put ratchet straps around it or something like that , that is not so invasive on the warranty? Ours is tied down and secured that way. 100 gals is almost 1000# in weight!
Y-Guy
Tri-Cities, WA
Posted: 05/01/12 08:00pm Link  |  Print  |  Notify Moderator
Very odd to have 3 go bad. I can't say I've read about that problem with other Vortex owners.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
HTElectrical
Las Vegas
Posted: 05/02/12 07:40am Link  |  Print  |  Notify Moderator
I have a 2009 284SA. Mine has 2 tanks instead of one. Maybe the reason they switched to 2 is because of the single large tank cracking. I believe they are 55 gal. ea.
2007 Duramax, Cognito 7"-9" Lift, 35" Hankooks
2009 284SA Vortex
pianotuna
Regina, SK, Canada
Posted: 05/01/12 08:04pm Link  |  Print  |  Notify Moderator
Hi,
Probably yankee gallons so 8.35 or 835 lbs for 100 gallons--plus the weight of the tank itself.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2btowed
glendale,az
Posted: 05/01/12 09:48pm Link  |  Print  |  Notify Moderator
You need to find an exact trailer like yours.Same problem, over and over, and nobody else having this problem? Sounds like they forget a cross brace,welded the frame for the tank wrong or something like this.They put a cross brace 1 inch off and your hanging the tank on its edge,not bracing it where its strong.Take measurments,and call tank manu,and see if the support is done correctly..Good luck with your answers.
08 Ranger
08 Grizzly x2
06 400ex
06 Honda 90
04 Kymco 110
