RV.Net Open Roads Forum: Travel Trailers: Electric tongue jack mod
 > Electric tongue jack mod
Page of 6
anaro
Mebane, NC
Posted: 05/01/12 03:56pm Link  |  Print  |  Notify Moderator
We got a Ultra Fab 3000 lb tongue jack for almost nothing at a camping world grand opening yesterday. Does anyone know how well it works or how easy it is to install? We weren't planning on buying it so we didn't measure our tongue jack diameter but are hoping it fits. It says it fits most 2" and 2 1/4" trailers. Our TT is a Zinger ZT26BL (30ft long) has a GVW of 7700 lbs (actual loaded weight approx 7000 lbs) and we estimated the tongue weight to be about 1000 lbs. I am totally guessing this will fit and is ok for the weight. Any advice on install is appreciated. DH thinks he will hook the TT to the TV while he switches it out. I have a 1 ton floor jack but he thinks the TV is better. I told him to chock the TV as well as the TT during this mod. Thanks
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
MitchF150
Washington, the State
Posted: 05/01/12 04:11pm Link  |  Print  |  Notify Moderator
Ours works quite well.. Have had it for about 7 years now. Simple to install.
I have 2 #5000 BAL stabilizer jacks up front, so I simply lowered them and raised up the old crank jack and unbolted the 3 bolts holding it on. Slipped in the new one and put the bolts back on. I think I had to put the ground wire under one of the bolts. Make sure you scrape off the paint directly under it.
I routed the POS wire and put on a round end thingy to attach to the battery. I just put it on the same + post as the trailer + wire.
Powered it on and it lifts the truck and trailer with ease. It's not the quietest of things however... Glad I have not had to use it in either a late night arrival or a real early morning exit!
You will want to pull the top cover over the gear assembly and give it some fresh grease at least once a year. I do cover mine when not in use, as the first time I pulled the gear cover off, I found where water had gotten in.. No big deal, as I just put some fresh grease in there and sealed it back up.
I've not had to use the "emergency" hand crank to date (knock on wood), but I make sure I carry it!
If you don't have strong enough jacks, the TV hitch is probably best, or some automotive jack stands would work too.
Good luck!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
anaro
Mebane, NC
Posted: 05/01/12 04:33pm Link  |  Print  |  Notify Moderator
So DH is looking at the jack and sees only one long wire. They did put some sort of short red wire in the bag but he has not yet figured out what that is or where it goes. I can see this supposedly easy mod going to the dogs soon.
sh410
Northwest
Posted: 05/01/12 04:39pm Link  |  Print  |  Notify Moderator
The one long wire goes to the positive post on the battery. The ground is the bolts that fasten the jack to the TT. The some sort of red wire has some sort of purpose ??? There should be instruction is the box that it came in.
ScottG
Bothell Wa.
Posted: 05/01/12 04:41pm Link  |  Print  |  Notify Moderator
The wire goes to your battery positive post. That's the only connection since the bolts that secure the jack provide the ground.
Scott, Grace and Wesly
H0NDA eu2000i
MitchF150
Humm.. As I recall (it has been 7 years! ) a black wire runs down the main shaft and is what get placed under one of the bolts. The red wire would be to the + battery post, but I don't recall that it was not already attached? It does have an in-line fuse connector.. It could be the one end of that?
Mitch
anaro
Mebane, NC
Posted: 05/01/12 04:42pm Link  |  Print  |  Notify Moderator
There is a very bad diagram that isn't helping DH. No real instructions in there at all.
MitchF150
Posted: 05/01/12 04:47pm Link  |  Print  |  Notify Moderator
Well, if you can hold on until I get home (couple more hours), I can take a pic and show you how mine is setup. I have the same exact model of jack, so I would think they would be the same, even after 7 years?
Mitch
anaro
Mebane, NC
Posted: 05/01/12 05:11pm Link  |  Print  |  Notify Moderator
Ok thanks. No rush, we aren't actually installing until sunday. He just had it out of the box looking at it today. He is very fond of not having to crank the tongue jack anymore you know.
handye9
Park City, IL 60085
Posted: 05/01/12 06:11pm Link  |  Print  |  Notify Moderator
Is there a fuse holder built into that short piece of red wire?
The one long wire goes to positive battery post, and, it should have an inline fuse.
As others have stated, the unit is grounded when bolted on to the TT frame.
Check out my mods
08 F250 Crewcab,4X4, SB
5.4, 4.10 gears
Flowmaster exhaust, SCT tuner
12 Flagstaff 831FKBSS (TT) and 00 Maverick 8801 (TC)
Wife and I
USN MCPO (E9) Retired (active duty 1973 - 1995)
Page of 6
