RV.Net Open Roads Forum: Travel Trailers: Receptacle box
 > Receptacle box
sbowman871
Wilmington, Ohio
Posted: 05/01/12 06:39pm Link  |  Print  |  Notify Moderator
Im planning to install a 50/30/20 amp electrical receptacle box outside on my barn. My TT only requires the 30 amp but i'm planning ahead in case I step up and need 50 amps for a future rig. I know the 30 and 20 will be 110 volts. What about the 50 amp, is it also wired at 110 volts?
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
ScottG
Bothell Wa.
Posted: 05/01/12 06:41pm Link  |  Print  |  Notify Moderator
50 amp RV is exactly like your electric range plug - 50A/220V.
Are you planning on doing this yourself?
Scott, Grace and Wesly
H0NDA eu2000i
Gene&Ginny
North Kingstown, RI
Posted: 05/01/12 07:24pm Link  |  Print  |  Notify Moderator
Here is one place to look, click here
As belairbrian said, many horror stories of licensed electricians doing it wrong.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
sbowman871
Wilmington, Ohio
Posted: 05/01/12 06:47pm Link  |  Print  |  Notify Moderator
No. I have a licenced electrician lined up for the instal.
belairbrian
Alabama
Posted: 05/01/12 06:54pm Link  |  Print  |  Notify Moderator
Might want to make sure he is familiar with RV plugs. More than one horror story has been posted here, where a "licensed' electrician saw a30 amp RV plug and wired it like a three prong dryer plug (220v). Then the owner plugs in and gets to replace a bunch of stuff.
Actually happened to a co-worker last fall, when a friend (also and electrician) did it.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
belairbrian
Alabama
Posted: 05/01/12 06:55pm Link  |  Print  |  Notify Moderator
Can't find the link right off but someone please provide the link to the RV pedestal wiring site.
JJBIRISH
Butler, PA, USA
Posted: 05/02/12 10:04am Link  |  Print  |  Notify Moderator
read this link
Love my mass produced, entry level, built by Lazy American Workers, Hornet
aftermath
Washington State
Posted: 05/02/12 09:29am Link  |  Print  |  Notify Moderator
Is this true? I don't think any RV service is 220V. I have a pigtail that adapts 50 AMP to 30 AMP. If it was 220V it would fry my entire system.
Help me on this one.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
belairbrian
Alabama
Posted: 05/02/12 09:46am Link  |  Print  |  Notify Moderator
It is accurate but you need to understand how it is wired inside the rv. The 50 amp plug has 2ea 110v legs, one neutral leg and one ground leg.
220v means you would read 220v if you connected a voltmeter acroos BOTH of the 110v legs. This has to do with the phase of the power on each leg. If you read the power from either "HOT" leg to neutral you would see 110v.
Most 50 amp RVs have 2 110v circuits. There are a few that actually use 220v to run some equipment.
As to why the 50 to 30 amp adapter works. The adapter connects to ONE hot leg, the neutral, and the ground. The extra Hot leg is not connected.
sbowman871
Wilmington, Ohio
Posted: 05/01/12 07:59pm Link  |  Print  |  Notify Moderator
Thanks G&G. That's exactly what I was looking for.
 > Receptacle box
