RV.Net Open Roads Forum: 2005 Dodge Ram 1500 good to tow 29 foot Orbit?
Search only in Tow Vehicles
 > 2005 Dodge Ram 1500 good to tow 29 foot Orbit?
Islander1
Long Island
Posted: 05/01/12 06:57pm Link  |  Print  |  Notify Moderator
Hi all!
2005 4 door Hemi with tow package, good to tow 29 foot Orbit 2006?
hmknightnc
Wilmington, NC
Posted: 05/01/12 07:07pm Link  |  Print  |  Notify Moderator
Hi and welcome to the forum.
Answer depends. What is the Gross Vehicle Weight of the trailer and how much heavier is it than the Hydrid you tow now? Do you think the difference in wieght is something you feel comfortable with?
Islander1
Long Island
Posted: 05/01/12 07:50pm Link  |  Print  |  Notify Moderator
GVWR 7500 on the Orbit
GVWR 4840 on the hybrid
hallock5
Posted: 05/01/12 08:08pm Link  |  Print  |  Notify Moderator
and what kind of terrain in the forecast?
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
hmknightnc
Wilmington, NC
Posted: 05/01/12 08:24pm Link  |  Print  |  Notify Moderator
You need to look up the actual specs for your truck but with a tow package 7,500# TT should be within all manufactures ratings for that 1/2 ton truck. Your probably close to GVWR max but I suspect your good or at least close enough if you maintain the truck well (not a member of the wieght police as I tow routinely over GCWR but I do like to stay with GVWR as much as possible and I never exceed axle or tire ratings)
Islander1
Long Island
Posted: 05/01/12 08:34pm Link  |  Print  |  Notify Moderator
Highways, North East
ib516
Up here!
Posted: 05/01/12 09:17pm Link  |  Print  |  Notify Moderator
I'd say yes. A 7500# GVWR RV is fine for a properly equipped (V8) half ton.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
APT
SE Michigan
Posted: 05/02/12 06:08am Link  |  Print  |  Notify Moderator
Payload and hitch ratings are going to be your limitations (assuming half ton). Plenty of power and a good trans with that truck. You will be adding about 400 pounds to the hitch weight over your current HTT. Have you ever weighed your current setup?
2012 VW Passat TDI
LIF
Long Island
Posted: 05/02/12 10:28am Link  |  Print  |  Notify Moderator
obviously purchase new hitch to handle the weight.
* This post was edited 05/02/12 10:57am by LIF *
Canadian9999
alberta
Posted: 05/02/12 11:35am Link  |  Print  |  Notify Moderator
i have a 2004 dodge hemi 1500 4x4 with 3.56 gear ratio and pull a 299 tango thats gvw is 7500 and i usually pull it around at 6500 pounds. the truck does ok but needs to rev and shifts more then i like. get used to 4000 rpm and 7-9 mpg. i thought of upgrading but my truck still only has 110000 kms on it and only time i drive it much is on holidays so ill keep it a few more years.
