Hello All,
I am going to be installing Bilstein shocks on my 2006 E-450 Fleetwood Jamboree 24D, I looked up the numbers in Bilsteins application chart, but they had 2 different part numbers, on was a B6C and the other was a B6, does the one with a C mean Class C?
Thanks,
Rick
edited 05/01/12 10:10pm by Momboy007 *
I installed Bilsteins myself on my E-350 back in 05 and I am about to replace them. They have 60K on them and don't feel like they did when I got them. I called the online shock dealer who I bought them from because I couldn't figure out which numbers to order. Seems Bilstein changed the numbers around. They make a set for class C's under 30ft and another over 30ft. They said I can use the over 30ft for a stiffer ride, but my E-350 is only 22ft and would probably ride too rough.
Bilsteins come with a Lifetime warranty. I would have to replace mine and send in the old shocks to Bilstein to check for defects. Not worth the trouble and shipping costs unless I see one has lost all its tension. Normal wear isn't covered.
If you want the online shock dealer that I used, send me a PM. Otherwise, shop around for the best price with free shipping if available.
I just checked it out and you take the same ones I do.
edited 05/01/12 10:59pm by DAS26miles *
