RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: GrilledJalapeno Poppers
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > GrilledJalapeno Poppers
farmer_boots
Weirsdale, Fl
Posted: 05/02/12 02:38am Link  |  Print  |  Notify Moderator
We love Grilled jaliapeno poppers they are so much easier to fix than deep frying. And what a hit when served to groups. But I have a hard time determining when the bacon is fully cooked. So most of the time I overcook the Jalapeno's to make sure the bacon is cooked.
What's a good method to determine when the bacon is cooked?
Because the bacon is so thin could I use an IR thermometer to measure the surface temp of the bacon? When it reaches 160+ it's ok to eat?
thanks
2006 Monaco Diplomat
fla-gypsy
North Florida
Posted: 05/02/12 05:51am Link  |  Print  |  Notify Moderator
Since bacon is cured you could probably eat it raw with no ill effects. I doubt there is a minimum temperature requirement. I always try to crisp and brown it up and just serve them. I prefer a medium hot fire and turn frequently. They are a treat
Mopar madman
Roseville
Posted: 05/02/12 06:26am Link  |  Print  |  Notify Moderator
When I make poppers for the grill I precook the bacon and add it to the cheese mix I am stuffing the jalepenos with. I also like using a smoked cheddar cheese! Now I am hungry!
Jeff Barsotti
Jim Cindy
Northcentral, PA
Posted: 05/02/12 07:02am Link  |  Print  |  Notify Moderator
While not a fan of it for a hot breakfast, the precooked bacon in the grocery store works great for these kinds of dishes. Anywhere you don't actually need the bacon fat in the recipe. Even does a respectable BLT while traveling. We have used Hormel.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Old-Biscuit
Across the USA
Posted: 05/02/12 11:35am Link  |  Print  |  Notify Moderator
Picked up a bunch of jalapenos & cream cheese this morning for grilling this afternoon.
Bacon ain't done until it's crisp........and a good char on the jalapenos.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Super_Dave
Sacramento, CA
Posted: 05/02/12 11:53am Link  |  Print  |  Notify Moderator
I find that about 1 minute with the bacon in the microwave before toothpicking it to the popper goes a long way in helping the popper and bacon finish about the same time.
As for precooked bacon, one does want some of the rendered bacon fat to flavor the popper, not just be a garnish.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
farmer_boots
Weirsdale, Fl
Posted: 05/03/12 02:33am Link  |  Print  |  Notify Moderator
Thanks for the ideas. I will try the precooked bacon and the microwave both sound like a very good solution.
rodbuilder
Cottage Grove, Or.
Posted: 05/03/12 02:49pm Link  |  Print  |  Notify Moderator
i agree with pre cooking the bacon but i only cook it about half way... i do mine a little different than most in that i make a one bite popper by cutting it into rings about 1 inch long... remove the seeds and some of the heat, then i stuff, wrap a half strip of bacon from top to bottom and stick a tooth pick in it and into the smoker for an hour... makes a great appatizer... already has the tooth pick in it...
Super_Dave
Sacramento, CA
Posted: 05/03/12 02:59pm Link  |  Print  |  Notify Moderator
I think finishing off in the broiler if one had to would also be a good way to crisp up the bacon without cooking the life out of the pepper.
ETex2
E. Texas
Posted: 05/04/12 07:42am Link  |  Print  |  Notify Moderator
Does anyone use the little cookers with holes in them made just for cooking them? I've always wanted to try them but it seems they'd be hard to cook up without one of these. I see these for sale at the flea market often but never in stores (not that I've looked for them).
