beemerphile1
I'm 57, I'm not a
cruz-in wrote: "I'm surprised, AGM's are normally more expensive than that)."
I can get the Exide MC-31 AGM200 Mega Cycle Group 31 100 AH battery for $169 and that includes core and tax.
That's a lot of money.
AH are king.
Here are the reasons I see for going with AGM;
Mount on their sides,
mount on ends,
mount in unvented compartment,
inaccessible for maintenance,
high charge rate.
If none of those advantages apply to you then AGM would be a waste of money in my opinion.
I have an AGM in a motorcycle because checking water would require removal of the fuel tank each time.
I have two 12v Deka GELs in my pup because they are in an unvented compartment and they are free to me.
My big trailer and all other vehicles have flooded batteries.
If it was me, I would go to Sam's Club or Costco and get two 6v golf car batteries for 220 ah and $150 total.
- Soren Kierkegaard
cruz-in
Southern Maryland
Westend,
That is a thought, as the AGMs do allow a bit more flexability in mounting, perhaps, I could figure a way to add a third if I found the two to not be enuff. I have to give that some thought. Adding a third would certainly take up some of my (vry minnimal) storage space.
pnichols
Santa Cruz Mountains
By fitting a couple of the Rolls AGM model 6V S6-275AGM batteries (10.31" X 7.13" X 10.76") in series into your storage area you get 250 amp hours. Look at the weight of these relatively small physical sized AGM batteries - 76 lbs. each - that's where those amp hours are coming from!!
(See the Rolls link in my post above.)
edited 05/03/12 01:43pm by pnichols *
Phil, 2005 E450 Itasca 324V Spirit
cruz-in
Southern Maryland
"That's a lot of money"
Absolutely...that is why I am so appreciative of all the input so I can make a cost effective decision.
Although in AGM land, $169 for a 2 year warranty Group 31 Battery with 100AH and 200 minutes of RC is a very good deal...although as you say...sitll lots of money.
MEXICOWANDERER
las peƱas, michoacan, mexico
AGM Much higher cost per amp hour. Much heavier per amp hour. No corrosion, no watering.
FLOODED: Inverse everything above.
mena661
JiminDenver wrote:
I probably have read your thread but after trying to get caught up after a 13 year break, I have read so many threads that knowing which is yours or connecting his two together gets mind boggling. Crap! Sorry Jim. I meant that last line for Cruz.
Trojan L16 6V's 740 Amp-hours
cruz-in
Southern Maryland
"Crap! Sorry Jim. I meant that last line for Cruz."
......and I read it several times and found it "spot on" with the type of info i was looking for......thanks for directing me to it...
JiminDenver
Denver, Co
No problem
It doesn't hurt me to go over the more techy threads again myself
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
