RV.Net Open Roads Forum: 320 AH of Wet Cell or 200 AH of AGM? What would U Choose?
 > 320 AH of Wet Cell or 200 AH of AGM? What would U Choose?
smkettner
Posted: 05/02/12 07:20pm Link  |  Print  |  Notify Moderator
Capacity is king. No need for superfast AGM charging with solar. IMO 80% down on an AGM is harder on the battery than 50% on the wet cell. Either can go down 60% or 70% for part time use without too much worry.
Only if you can reposition the AGM to get the capacity up... but the extra battery(s) will increase cost.
675 watts solar
KD4UPL
Swoope, VA
Posted: 05/02/12 07:24pm Link  |  Print  |  Notify Moderator
AGM batteries have a lot of advantages. Many of them irrelevant to the RV world. They don't out gas but RV's typically have vented battery compartments.
They can take a much higher charge current but most RV's have kind of weak chargers.
They can survive more physical vibration like an off road vehicle or machinery would subject them to, but RV's typically don't go extreme off roading.
They don't require checking the water levels but that's really quick and easy.
Get the larger capacity flooded batteries.
mena661
Posted: 05/02/12 08:42pm Link  |  Print  |  Notify Moderator
smkettner wrote:
Capacity is king.
Oh yeah!!!! Nuff said!
Trojan L16 6V's 740 Amp-hours
full_mosey
Oklahoma
Posted: 05/02/12 09:32pm Link  |  Print  |  Notify Moderator
cruz-in wrote:
Humm so no takers for the AGMs?
Yes, I saw right through your opening post! You want AGMs.
I use AGMs.
Here are the reasons for AGM:
1. You are unable or unwilling to perform the maintenance on FWC,
2. You have living space issues, or
3. You fly, sail, or rock-climb.
I have living space issues.
What is your reason?
HTH;
John
christopherglenn
a little over an hour from Yosemite
Posted: 05/02/12 09:43pm Link  |  Print  |  Notify Moderator
I am looking at putting an AGM in, along with replacing the converter with an inverter/charger, then a 290 watt solar on the roof. I figure running the generator for about an hour in the AM while the kids abuse the shower (hairdrier) should put back most of what came out of the battery overnight + breakfast. The solar can do the rest during the day.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
crcr
Phoenix, AZ
Posted: 05/02/12 10:10pm Link  |  Print  |  Notify Moderator
You didn't mention this as an option, but I will throw it in. I would without hesitation go for 2 6V GC batteries. IMHO, that is your greatest bang for the buck for RV use.
mena661
Posted: 05/02/12 10:26pm Link  |  Print  |  Notify Moderator
I don't think he has room for 6V's.
JiminDenver
Denver, Co
Posted: 05/02/12 10:46pm Link  |  Print  |  Notify Moderator
He should have room if he can do two 12v. He would only have 220 ah or 110 ah usable before 50% discharge. The flooded 12v pair would still be more at 155 ah at 50%.
If the flooded 12v are GC type, wouldn't they carry many of the advantages of 6v cg batteries?
One thing not discussed is his solar and the possibility it will make critical choices about battery capacity mute.
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
ken burke
usa
Posted: 05/02/12 11:18pm Link  |  Print  |  Notify Moderator
So, what would be best . . . . ONE 6 volt set (two 6 volt) GC batteries, OR, TWO 12 volt batteries (type 24 or 27)?
thanks ken
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
smkettner
Posted: 05/02/12 11:21pm Link  |  Print  |  Notify Moderator
2x 6v Golf Car = 220 Ah
2x 12v Sweeper = 310 Ah
I will take the sweepers
