RV.Net Open Roads Forum: Class A Motorhomes: power managent module
 > power managent module
carefreerv
home
Posted: 05/02/12 05:08am Link  |  Print  |  Notify Moderator
I have a 2008 Winnebago Adventurer. The lights on the Power Managment system have stopped lightning but I have full 50 amp service. Does anyone know where the fuses are for this? Another silly question-there's no hot water in the shower but hot everywhere else????
rexabbot
Cumming GA
Posted: 05/02/12 05:39am Link  |  Print  |  Notify Moderator
What power management do you have?
dougrainer
Carrolton, Texas
Posted: 05/02/12 06:18am Link  |  Print  |  Notify Moderator
The fuse is located ON the Power module inside the 120 breaker panel system. Doug
dougrainer
Carrolton, Texas
Posted: 05/02/12 01:15pm Link  |  Print  |  Notify Moderator
carefreerv wrote:
It's Power Line 2004. I've checked the breaker panel in the coach I have circuit breakers and white reset buttons for 12 volt. Are the fuses behind the gray metal panel?
The Control board for the EMS is located behind a metal panel cover next to the main breakers. REMOVE the metal panel cover for the main breakers and you should see the control board and wiring. Doug
carefreerv
home
Posted: 05/02/12 10:44am Link  |  Print  |  Notify Moderator
