RV.Net Open Roads Forum: Tech Issues: Which power sugre portector
 > Which power sugre portector
yankeecamper
FUQUAY VARINA, NC, USA
Posted: 05/02/12 07:24am Link  |  Print  |  Notify Moderator
I have ordered a Surge Guard RV Voltage Regulator. After reading more I find they recommend using a Surge Guard with this unit.(Voltage Regulators work with Surge Guard power protection devices (sold separately) to provide surge/spike/miswired pedestal protection to RV and appliances.)So why don.t I just buy the Surge Guard? Which one is best or do I need them both?
2nd Will a 50amp unit work on a 30amp with th 30 amp adapter?
Barb and Rich, Fuquay Varina, NC
2006 Dodge Ram 3500 SLT Quad Cab
Dually 4x2
5.9-Liter HO Cummins Turbo Diesel
2010 Grand Junction 350RE 4 slides
parkdep
Lapeer Michgan USA
Posted: 05/02/12 11:07am Link  |  Print  |  Notify Moderator
Yes a 50amp will work on a 30 amp pedestal with a adapter. Here is a link on surge guard information that maybe helpful to you. Surge Guard
tvman44
Southwest Louisiana
Posted: 05/02/12 12:37pm Link  |  Print  |  Notify Moderator
Get one made by Progressive Industries, far superior to the other brand.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
TechWriter
On The Road
Posted: 05/02/12 12:55pm Link  |  Print  |  Notify Moderator
Let me guess . . . you own one from Progressive, right?
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
steveownby
Cosby, TN
Posted: 05/02/12 01:21pm Link  |  Print  |  Notify Moderator
Tvman44 is correct about Progressive. I do not own one but have researched them extensively. Only one reason is necessary. The Progressive is the only affordable unit set up for the RV environment which will protect against an open neutral. Open neutral or floating neutral is not uncommon and can cause extensive damage in an instant.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
TechWriter
On The Road
Posted: 05/02/12 02:21pm Link  |  Print  |  Notify Moderator
Not true - Surge Guard Product Comparison
On the "affordable" part, I believe Progressive & TRCI Surge Guards are similarly priced.
yankeecamper
Posted: 05/02/12 05:15pm Link  |  Print  |  Notify Moderator
Let me ask the question a little different. If I get the Surge Guard RV Voltage Regulator do I still need the surge protector. Or do I only need the surge protector and not the Surge Guard RV Voltage Regulator.
accsys
Green Cove Springs, FL
Posted: 05/02/12 08:36pm Link  |  Print  |  Notify Moderator
Get you one of these or another with the same capabilities. Yes I installed one of these just before my current summer trip and I can tell you I feel much better using it than the others I have tried, including the SurgeGuard ones. The PI units do a lot more than surge protection. I plug in and if the power is good it lets it on through. I can check the voltage and amps used on both legs anytime I wish. If the voltage is out of range it will shut the power down and reset on its own. It's nice to know your ACs will not be exposed to 108 volts or less while you are out during the day but will not be shut off any longer than necessary.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
PatrickA51
Lost
Posted: 05/02/12 08:43pm Link  |  Print  |  Notify Moderator
X2
NanciL
Bakersville, NC, USA
Posted: 05/02/12 04:56pm Link  |  Print  |  Notify Moderator
What ever one you get, make sure you pay the extra bucks to get the one that automatically resets after the fault is corrected.
I made the mistake and got the cheaper one that doesn't reset, and there have been days when we come home from an all day kayak paddling trip only to find the trailer hot from no Ac since the unit didn't reset.
Jack L
Jack & Nanci
