RV.Net Open Roads Forum: Sofa to Dresser Upgrade
searfoss
East Stroudsburg PA USA
Posted: 05/02/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I was looking at the jack knife sofa in the TT
And noticed the wasted / unused space beneath it.
And decided that the space could be used for DW and I to keep our Clothing, so I removed the Jack Knife Sofa
Measured out the area and removed the frame front.
My Buddy gave me some oak he had that had gone Moldy that I decided to make the dresser from.
Off to the Wood Shop to see what I could come up with;
I wanted to use biscuits to hold the frame together but decided to use a Domino Biscuit using a Festool.
Cut and glued the face frame and clamped it together
Glued all the oak together into a big slab which will get cut down into individual drawer fronts
After cutting down the drawer fronts they were run through the shaper to give them the pattern and detail.
This particular cutter puts a back finger grip on the drawer front so a pull handle is not needed.
The drawers themselves came as a kit from BarkerDoor.com,
I chose UN-ASSEMBLED - 5/8" thick (11 ply) Baltic birch plywood Dovetailed joint construction.
To be real, I am impressed.
I put three coats of ZAR on the drawers and used 0000-steelwool between coats for a smooth finish
Glued the Dove Tails and assembled the drawers.
Matching the interior stain proved to be more a challenge than I anticipated,
however I found a nice oil-based gel stain that was so close only I could tell the difference.
After three coats of stain I installed the face frame.
I used Pocket Screw Joints to attach the frame from the back and not mar the finish. (Also makes it easier to remove and install in another RV)
Someone gave me three sets of RV8400 full extension draw guides, the price was right to I decided to use them.
All three drawers installed.
Attached the drawer fronts to the Barker Drawers and it looks awesome!
In the close up you can see the back finger grip on the drawer front.
Re-installed the Sofa and DW and I have a place for our clothes!
UPDATE: Since the original completion of this project,
I added magnetic cabinet door latched to the back of the drawers to keep them from rolling open if the TT was not quite level.
And a simple door lock from Home-Depot on the back of the drawer front to keep it secure during travel.
Just lift up the front of the Sofa reach in and lock it and it is secure.
PLEASE if you comment do not quote the post, there are way too many pictures that will bog down the blog…….
My Photo Bucket Log!
Moderator edit to re-size pictures to forum limit of 640px maximum width.
* This post was last edited 01/14/13 10:33am by an administrator/moderator *   View edit history
Poconos Pennsylvania
2007 Gulf Stream Gulf Breeze 23TRS
2004 Dodge Ram 1500 Quad Cab
4X2 5.7 hemi 3.55 rear
RIP Mike, we miss you so much
amandasgramma
Oregon
Posted: 05/02/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Great job!
RedRollingRoadblock
Oregon
Posted: 05/02/12 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. That gives me an idea...Nice job too.
Impkitti
Keyport, Wa
Posted: 05/02/12 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Very clever and VERY well-done!
Ellen
1 Retired Husband
2 Dogs
2 Cats
1 2008 F350SD Truck
1 2011 Arctic Fox 29-5E
2 Cars
1 House
Not Enough Time
downtheroad
Pacific Northwest
Posted: 05/02/12 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Beautiful...
Wouldn't it be nice if manufacturers built all our rigs with that kind of thought and quality?
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
goducks10
Keizer OR
Posted: 05/02/12 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Exc job.
BarneyS
S.E. Lower Michigan
Posted: 05/02/12 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Beautiful job, excellent and well done post, and I appreciate your comment at the end about quotes.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
ScottG
Bothell Wa.
Posted: 05/02/12 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Ours came with one large drawer under there but it sure isn't that pretty.
Nice work!
BTW, what did you use for drawer glides? I assume there's some way of keeping them from sliding open while under-way?
Scott, Grace and Wesly
H0NDA eu2000i
searfoss
Posted: 05/02/12 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Keeping them closed during transport has been the issue, I have looked at many RV & Boat drawer locks. The problem is, I don't want a knob sticking out so I haven't found the right lock yet.
DW told me I was over-thinking the problem she handed me a simple door lock from Home-Depot, so I installed on one these inside of each drawer and just lift up the sofa and lock it during travel. If I find anything better I will let evryone know.
ScottG
Bothell Wa.
Posted: 05/02/12 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could use some child-safe drawer catches? Something like this:
I'd hate to mar-up those gorgeous drawer fronts with anything.
