RV.Net Open Roads Forum: Class A Motorhomes: CAT 3126 Fan Bearing Lube
 > CAT 3126 Fan Bearing Lube
EdNdonna
Tipton,Calif.
Posted: 05/02/12 10:34pm Link  |  Print  |  Notify Moderator
double post
2006 Fleetwood Bounder 34H Cat C7 300hp
wolfe10
Posted: 05/03/12 07:22am Link  |  Print  |  Notify Moderator
gswcgi wrote:
I just pass this because I have heard CAT engines manufactured after 2003 that still had grease zirks on them.
3116 & 3126 fan pulley has a zerk fitting location on engines up to engine serial number HEP15357 (engines produced before 1/03). Engines produced after that date have sealed bearings.
Both sealed and greasable bearing housings/bearings are available from Caterpillar as replacements. So, a greasable could have been replaced with a sealed and visa versa.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
gfs1943
Whitney, Texas
Posted: 05/03/12 07:41am Link  |  Print  |  Notify Moderator
What would really help would be an extended zerk fitting. I've seen zerks an inch long on aircraft. As it is now on the fan bearing, I had to grind off one side of a grease gun fitting to slide onto the zerk behind the fan pulley. With a longer zerk, it would stick up above the pulley so a standard gun would fit onto it. That wouldn't eliminate the requirement to open the engine hatch, but I like to see the top of the engine occasionally. I need to look through my old parts bins and see if I may have a longer zerk somewhere.
gfs1943
USAF, Retired (1962 - 1983)
'00 Itasca Horizon 36LD
Cat Diesel Power
2006 Honda CR-V
RCtime
So. Calif.
Posted: 05/03/12 08:09am Link  |  Print  |  Notify Moderator
To lube the zirk fitting on my coach, I purchased a smaller hand held lube gun, they have a smaller diameter fitting that fits in between the pulley and the cyl. head with no problem.
A few squeezes on the trigger and its done.
Try Autozone or Pepboys
Ron
2002 34HD Winnebago Journey DL, Cat. 330/freightliner
2004 Honda CRV - Garmin 1490t
Great wife & Cavalier King Charles Spaniel
TT/N
stardalo
ny
Posted: 05/03/12 09:10am Link  |  Print  |  Notify Moderator
Man, this has been a hot topic. It has me panicked that mine has not been done in awhile. What kind of grease did you use in the smaller gun? Also, on the journey (i have same rig) did you need to remove anything other than the engine plat to reach it with the smaller gun? thanks.
RCtime
So. Calif.
Posted: 05/03/12 09:47am Link  |  Print  |  Notify Moderator
They use the same grease the larger guns use. It just comes in a smaller tube.
I was curious----Just looked at my grease gun. It is now loaded with 3OZ. Marine-Multi-purpose-water resistant bearing grease.
The water resitant part is not needed.
You can get regular chassis lube grease also in the 3OZ. size.
I thought a grease specifically for bearings would be a good choice.
Comments???
Just remove the 4 bolts and slide back the metal engine plate.
I kinda feel for the zirk with my left hand, find it, then just guide it onto the end of the Zirk. If you are real nimble, then crawl in deep with a flashlight and mechs. mirror and once you find it you will see why its kinda difficult to see, everything is sooo yellow, as was my zirk and it sets directly behind the pulley and cyl. head
* This post was edited 05/03/12 10:38am by RCtime *
wayrid
Elsberry, MO
Posted: 05/03/12 04:38pm Link  |  Print  |  Notify Moderator
They make a grease needle that I use to grease the bearing on my Cat engine. Works great.
EdNdonna
Tipton,Calif.
Posted: 05/03/12 10:38pm Link  |  Print  |  Notify Moderator
Caterpillar has zerks that are about an inch long
jferre9570
Southeastern MA, USA
Posted: 05/04/12 05:23pm Link  |  Print  |  Notify Moderator
Also try McMaster-Carr McMaster Zerks
John & Diane
1996 Beaver Monterey 3403
2002 Ford Windstar toad
TEO
Inverness, FL, USA
Posted: 05/05/12 11:40am Link  |  Print  |  Notify Moderator
Today I finished the modification and now have the lube line coming down on the right side of the motorhome near the batteries. The worst part of the job was getting off the old zerk fitting. I couldn't reach it with anything because it's so close to the pulley. I really didn't want to remove the fan and pulley to get at the zerk. Instead, I used my Dremel tool to grind away a small indentation in the pulley rim so I could get a socket in place. It worked like a charm and I don't think the little bit I shaved off will have any effect on the balance. It was a bit more difficult than I thought, but I will not have to take apart the bed to get to the fitting anymore.
Thanks to all for your help. The picture on the CAT Club website tells it all.
Paul & Helen
2002 Winnebago Journey DL
1999 Jeep Cherokee toad
Yellow Lab, Jodie, Chocolate Lab, Coco , and Lab/Golden mix, Sandy.
FMCA 98905
http://ptempesta.blogspot.com
