RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): lcd upgrade
ssands
Nerk, Ahia
Posted: 05/02/12 12:31pm Link  |  Print  |  Notify Moderator
I know I've seen posts of some of the fantasic ways you guys have modified your RV to accommodate a LCD/LED tv. Can someone point me to some of them? I've looked all over and can't seem to find then.
Thanks in advance.
"My reading of history convinces me that most bad government
results from too much government."
"No free man shall ever be debarred the use of arms."
--Thomas Jefferson
Steve,Sharyl and Fritz
1999 Winnebago Adventurer 37G
2009 Saturn Vue
Sandia Man
Rio Rancho, NM
Posted: 05/02/12 01:02pm Link  |  Print  |  Notify Moderator
We just removed analog set and installed a board within the cabinet to mount the swing arm for the flatpanel. Has withstood a couple of seasons of camping without any issues.
tkcas01
Roaming Fulltimer
Posted: 05/02/12 02:12pm Link  |  Print  |  Notify Moderator
Here's mine. Made a similar mount for the TV up front.
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/24868358.cfm
My last known location (is here)
    ssands
    Nerk, Ahia
    Posted: 05/02/12 03:52pm Link  |  Print  |  Notify Moderator
    Here's how I installed the one in our bedroom. It's at the perfect angle for watching in bed. This TV was a 12" and has been replaced with a 19" Visio.
    Now To figure out how to hang the front one.
    tkcas01, Your install got me thinking. Thanks.
    Kiwi_too
    Western, WA
    Posted: 05/02/12 07:55pm Link  |  Print  |  Notify Moderator
    We changed our 21 inch CRT to a 32 inch Vizio LCD. There was not enough room inside the cabinet for the 32 inch. We would have had to mod the cabinets but did not want to do that so we surface mounted the 32 inch. Took plywood, vinyl upholstery and piano hinge. We also added a surround sound home theater, behind the TV, with our Sat controller, receiver, Western Digital TV video player and RF extender. Home theater has wireless rear speakers. This reduced our need to run speaker wire.
    Below is a look at the front of the coach. Notice the addition of the speakers in the upper corners and surround speaker below the TV.
    Before
    After
    Stereo/Storage behind
    May God bless your travels
    Me, The Wonderful Wife
    and two Spastic Border Collies
    U.S. Army Retired
    2004 Coachmen Aurora, 3480DS
    2007 Saturn Outlook, FROG
    ssands
    Nerk, Ahia
    Posted: 05/04/12 02:23pm Link  |  Print  |  Notify Moderator
    It's all in. Now just need to figure out how to post nice size pictures like the rest of you.
    ryanallie1
    Magalia, Calif
    Posted: 05/04/12 03:57pm Link  |  Print  |  Notify Moderator
    Hi All.
    Yep, some pictures of some one elses TV Mods is fine, if you have the exact same Motorhome and your going to use the exact same LED TV also.
    No Kidding ? A lot of Motorhomes are way different in many ways. It also depends on what size OEM CRT TV that is comming out and what size LED TV you want to put back in. So basically every TV Mod is a bit different. So yours will probably be different also.
    Other pictures of TV Mods can give you some ideas, but your still going to have to figure out how to do yours, and to make it work. As you have seen in some of the pictures, some are very easy to do and others are very hard to do. That also is your choice also.
    A lot just depemds on how much time and money you want to put into your TV Mod, and how nice you want it to look when your done.
    The more skills that you have and the more tools that you have, also makes it a lot easier also.
    Good Luck. Happy Travels. Dan & Jill
    1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
    ssands
    Nerk, Ahia
    Posted: 05/04/12 05:37pm Link  |  Print  |  Notify Moderator
    Before;
    TV removed;
    The Mount;
    New 24" Samsung with Blu-Ray player under TV;
    Thanks for the suggestions. They were a great help.
