Duke-44
Wyoming Rockies
I bought this diesel engine truck several years ago because I was tired of being the last one, pulling my 5er, up the hill and it was the least noisy and smelly diesel out there.
I have always seen, heard and smelled people's idling diesel trucks almost everywhere when parked.
I don't idle mine any differently than when I drove my gasser.
What am I missing, besides a higher fuel bill?
Helimech
Chino Valley
Got me, shut it off
Turtle n Peeps
California
Duke-44 wrote: I bought this diesel engine truck several years ago because I was tired of being the last one, pulling my 5er, up the hill and it was the least noisy and smelly diesel out there.
In the old dinosaur days turbos had only oil cooling and soft babbitt bearings and diesel fuel was about 15 cents a gallon. Low quality oil coked and would plug up the bearing holes and return line and hole.
After a good long pull up a hill at WOT the turbo would be smokin hot and so would the oil. If you shut the engine off it could coke up and smoke the bearings.
The long and short of it is old habits die hard. I have driven turbocharged gas engines since the early 80's and they get much hotter than a diesel turbo. I always drove it like any gas engine to the much chagrin of some old trucker warnings. Never lost a turbo.
IMHO and other expert opinions say a modern diesel with water/oil cooling does not need to be idled at all.
IOW your not missing a thing.
That being said, a little common sense comes into play. It would never be a good to go WOT up a 15% hill for a half an hour and when you get to the summit turn the engine off. Even in those conditions 1 or two minutes of idle time is fine. But that goes for any engine, turbo'ed or not.
outside the fire"
45Ricochet
North Idaho
About the only time I idle is after a long pull (cool turbo down), when I want the heater or A/C on and if I haven't gotten to normal operating temperature (winter months).
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
downtheroad
Pacific Northwest
Real men only drive Dodge 24 valve rattlers...and they always let them idle for at least 30 minutes every morning at 5AM before heading out to go fishing.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
katysdad
Virginia
Only time I let mine idle is when stopping after a long run or heavy load to let the internal heat dissipate and for the turbo to cool down so it doesn't cook the oil in the turbo bearings,usually about 5 minutes. Other than that there is no need to waste fuel. Long idle times can also result in low combustion temperatures which result in unburned fuel washing the oil off the cylinder walls and causing premature ring And cylinder wear.
Dodge Ram 3500 DRW Diesel
ib516
Up here!
Read your owners manual. The reason for idling (in some rare instances) is in there.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
jmckelvy
North Alabama
katysdad wrote: Only time I let mine idle is when stopping after a long run or heavy load to let the internal heat dissipate and for the turbo to cool down so it doesn't cook the oil in the turbo bearings,usually about 5 minutes. Other than that there is no need to waste fuel. Long idle times can also result in low combustion temperatures which result in unburned fuel washing the oil off the cylinder walls and causing premature ring And cylinder wear.
X2
I just turn mine off regardless. The Edge J/A has a turbo cool down timer which I have set at 320. The truck automatically shuts down when the EGT reaches that level.
06 Dodge 3500,Dually,CTD,Auto,QC,4X4,Torklifts,Fastguns
2008 Northstar 8.5 Arrow, 100W AM Solar
US Navy 1964-1968, 2-Tour Vietnam Vet
States camped in with Northstar.
Wingnusa
Scott and Brenda Retired and Wingn the USA
Get a pyrometer installed and that will be your only issue on idling. Just make sure your turbo is cooled down to 350 degrees or less before you shutdown.
Scott and Brenda Schnelle
Jasmine the Schnauzer/Sierra the CKCS
2006 KZ Escalade 36CKB
2007 Chevy C5500
FT Class of '06
Lifetime Good Sam's members
Lifetime NRA member
Sporting Clays Competitor, NSCA #621387
Level 1 Sporting Clays Instructor
NRA RSO
My Site
