RV.Net Open Roads Forum: General RVing Issues: Bad smell
 > Bad smell
Louie & Eva
New Haven Ct
Posted: 05/02/12 03:23pm Link  |  Print  |  Notify Moderator
I posted the other day about a bad smell coming from the front storage and the large side storage from a used 5th wheel we just purchased. We have not gotten a chance to clean those again, I have been working on cleaning the inside. My husband has had the doors open to the storage areas. This morning when I went out there, the smell was very mild. I was working on cleaning the inside, running the water, The smell is so bad right now, I can smell it as soon as I come out of the house, I can even smell it in the back yard. Do you think I have a leek somewhere in the gray tank? I am so made right now!!!! I'm thinking these people know that this was a problem.
Montana 2008 Mountaineer travel trailer 32FLD
2006 Ford F350 PSD, Lariat, CC, LB, SRW and Blue ox sway control
SWD
Land of Living Skies
Posted: 05/02/12 03:27pm Link  |  Print  |  Notify Moderator
Well its too late to take the unit back. Keep cleaning and cleaning and just let it air out. Lots of Lysol/Pinesol, whatever it takes , just keep at it. Is it a "sewer" type smell? May have a plugged and broken vent stack that is venting all that sewer gas thru the trailer.
Louie & Eva
New Haven Ct
Posted: 05/02/12 03:35pm Link  |  Print  |  Notify Moderator
The smell is more on the outside of the trailer. I NEVER TAKE ADVANGE OF ANYONE,and it really hurts when someone does it to me. I need to find out where this is coming from it needs to be fixed.
SWD
Posted: 05/02/12 03:51pm Link  |  Print  |  Notify Moderator
Yeah..I hear you. Its happened to me too! If I sell something I answer any and all questions truthfully. But now that you have the unit you'll just have to persevere. Where on the trailer does it smell the most? Did you check underneath?
Can you describe the smell?
dbbls
Missouri
Posted: 05/02/12 03:54pm Link  |  Print  |  Notify Moderator
Could it be a animal that got in somewhere and died? I have heard of this happening.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Louie & Eva
New Haven Ct
Posted: 05/02/12 04:03pm Link  |  Print  |  Notify Moderator
dbbls, I don't think that it's an animal, the smell was very mild almost gone until I ran the water.
SWD, To me it smells like gray water, and that would make sense, since it was worst when I was running the water inside to clean. The funny thing is that I smell it the most in the storage unit under the pin and the large one next to it, but there is no water spots anywhere.
pianotuna
Regina, SK, Canada
Posted: 05/02/12 04:05pm Link  |  Print  |  Notify Moderator
Hi,
Is it a sulfur smell? If so, one of the "house" batteries may be over charging or failing in some way.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
korbe
Northern California
Posted: 05/02/12 04:26pm Link  |  Print  |  Notify Moderator
I would clean the tanks too. That will rule them out. If it smells worse when you run the water, it could be the fresh water system that needs a cleaning.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
pianotuna
Regina, SK, Canada
Posted: 05/02/12 04:29pm Link  |  Print  |  Notify Moderator
Hi,
"until I ran the water". Sometimes hot water tanks develop a very bad smell. The water may smell like sulfur.
Drain down the system completely and sanitize it.
Louie & Eva
New Haven Ct
Posted: 05/02/12 04:44pm Link  |  Print  |  Notify Moderator
No it's not sulfur. I want to thank everyone for their help. If you can think of anything else PLEASE post.
 > Bad smell
