RV.Net Open Roads Forum: General RVing Issues: Bad smell
 > Bad smell
pianotuna
Regina, SK, Canada
Posted: 05/02/12 05:23pm Link  |  Print  |  Notify Moderator
Hi,
Does it smell like rotten eggs?
Can you characterize the smell for us?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
falconman
On The Road!!
Posted: 05/02/12 05:35pm Link  |  Print  |  Notify Moderator
Most trailers have Air addimittance valves to aid with grey water tank venting. These are in addition to the vents that run from the tank directly to the roof. You may find several, usually under the sinks and near the shower drain pipe. You might have to remove some cabinet drawers to find them. They act as a one way valve to alllow air into the drain pipe while draining. They are spring loaded to close when not needed. They are mechanical so they will fail, resulting in the grey water odor inside the unit. Easy to replace and not expensive, available at most hardware stores. Now, these are really cheaply constructed and there are much better ones which cost much more which I recommend. However, they are usually larger in size, so verify they will fit.
YNOTRIDE
Corona, CA
Posted: 05/02/12 05:49pm Link  |  Print  |  Notify Moderator
If I was in your situation I would go spend 3 bucks on a few gallons of bleach. I would pour one gallon in my fresh tank then fill it full of water. And another gallon in my Grey tank.
I would then run all my faucets for a few minutes from the fresh water tank to get the bleach in all my lines.
After letting it sit overnight I would drain my fresh and grey tanks and refill with fresh water and repeat the steps above a few times with clean water only.
03 Ragen 29n TH
05 Ford F250 Diesel
06 Suzuki DRZ400S Plated
08 Yamaha FJR1300
09 Kawasaki KLX250S Plated(wife)
07 Ninja 650R(wife)
10 Kawasaki KLX110L(Boy)
klm
SIOUX FALLS, SD
Posted: 05/02/12 05:56pm Link  |  Print  |  Notify Moderator
Drain the water heater, if it has an anode rod - replace if necessary. Otherwise, get a wand and flush out the water heater tank - you will be surprised at all the "glunk" that is in there. And, yes - it stinks.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
PI_Tom
Posted: 05/02/12 06:13pm Link  |  Print  |  Notify Moderator
Does the unit have a water heater? If so, how long has it been since it was used? If the smell resembles rotten eggs the water heater may be your issue. You can remove the anode and flush the tank before storing, make sure the water heater tank is empty. In the alternative, you can buy a coach with Hydronic Heating to eliminate the water heater.
Tom C
dbbls
Missouri
Posted: 05/02/12 06:16pm Link  |  Print  |  Notify Moderator
DO NOT POUR ONE GALLON OF BLEACH INTO YOUR FRESH WATER TANK! You will be forever getting the smell out. One fourth cup is the recommended amount.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Johnworth914
USA!
Posted: 05/02/12 06:20pm Link  |  Print  |  Notify Moderator
I think the idea of sanitizing the tanks is not bad, but the amounts are way to much. That much bleach can damage the tank sensors and even the drain valves.
A few ounces per tank is more than enough.
I also agree that the water heater should be drained and thoroughly cleaned
Have you checked for a wasps ( or bird) nest in the vent pipes?
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
rondeb
Pacific Northwest
Posted: 05/02/12 07:10pm Link  |  Print  |  Notify Moderator
It may be as simple as one of the p-traps may be void of water and letting smells in. Pour water into all traps including shower, etc. and Maybe? I know that the gray tank can smell horrible.
fla-gypsy
North Florida
Posted: 05/02/12 07:20pm Link  |  Print  |  Notify Moderator
My guess (thats all it is) is the water heater (they can develop a bad smell if not drained occassionally) a trap that does not have water in it (run water into every drain) or an inside vent that is not working properly. All of these can be checked and eliminated quickly
J-mans Dad
SF Bay Area
Posted: 05/02/12 11:16pm Link  |  Print  |  Notify Moderator
The funny thing is that I smell it the most in the storage unit under the pin and the large one next to it, but there is no water spots anywhere.
Sounds like a battery being overcharged. Does it smell like rotten eggs?
 > Bad smell
