geo11RT
Missouri
I am looking at getting a TT. One I am interested appears to have some "buckling" near the right front corner. What causes this and is this a sign of a bigger problem down the road? See the pic.
downtheroad
Pacific Northwest
I'd run from this one....looks like a bad case of delam. Could be bigger problems underneath the skin.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
WI Bowhunter
Shiocton, WI
I would be very skeptical. With that buckling, I would guess there is room for moisture underneath. That is never good!
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
82corvette
Southeast Nebraska
Keep looking, this one is going to be expensive to fix!
geo11RT
Missouri
Thanks guys, that's what I wanted to know!!!
gmw photos
midwest
I would say that as always, "it depends". How cheap can you buy this camper ? And what else needs to be repaired ? It's like anything, if you can get it cheap enough, then it could be worth picking it up and fixing it.
Otherwise....keep looking until you find something in better shape.
jim87vette
Arizona
It might have some frame issues?Hard to say for sure until you really look at it.
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
dodge guy
Bartlett IL
That whole front wall looks like it is delaminated. judging by the way the wall is expanded between the window and the sides.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
Admiral
Upstate Ohio
From where it starts it looks like the amber running light was the source of the leak. There's no excuse for preventive maintenance.
For want of 10 cents worth of caulk you get thousands of dollars in repairs. I'll bet the inside is as worse.
2004 Damon Daybreak 2960F V-10
05 Honda Element LX
Compassion should be voluntary, not mandatory.
boosTT
Milwaukee
Not OK!
