RV.Net Open Roads Forum: Forum Technical Support: Posting issue
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Posting issue
ploiselle
South Shore, MA
Posted: 05/02/12 04:17pm Link  |  Print  |  Notify Moderator
FYI
I am not able to post through RV.net, but can post through Woodalls.
No response necessary.
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
pulsar
Lewisville, NC
Posted: 05/02/12 04:33pm Link  |  Print  |  Notify Moderator
It would be helpful to know what happens when you try to post. Does a login screen come up and you can't get past it? Or, you enter the post and click on Post Message but nothing happens?
Without further information, I would suggest that you delete cookies and temporary Internet files. Login through the RV.Net portal and see what happens.
BTW, I've posted via the RV.Net portal, off and on, all day.
Tom
accsys
Green Cove Springs, FL
Posted: 05/02/12 08:14pm Link  |  Print  |  Notify Moderator
It's happened to me three times this evening through the RV.NET portal. Same indications as Paul outlined.
On Edit. Yet this message posted correctly 20 minutes later.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
ploiselle
South Shore, MA
Posted: 05/02/12 06:37pm Link  |  Print  |  Notify Moderator
Hi Tom,
I also posted a several times with no problems, but had problems twice.
After pressing post message, I get the initial box stating that it might some take time during busy times, the box disappears and it just hangs like the internet is down, finally timing out to a blank screen.
During one time, while it was timing out I opened, copied to and posted under the Woodall's portal with no issues. Another time, I opened several other sites to see if it was an internet problem here.
Thanks
Paul
pulsar
Lewisville, NC
Posted: 05/02/12 07:15pm Link  |  Print  |  Notify Moderator
Is this happening currently? or is it something that was happening over the weekend.
There were server issues that affected all of the forum, but the RV.Net portal more than the others. The symptom was "timing out."
Tom
ploiselle
South Shore, MA
Posted: 05/02/12 07:31pm Link  |  Print  |  Notify Moderator
This afternoon, early evening Eastern
NorthernLimits
Michigan
Posted: 05/03/12 06:21am Link  |  Print  |  Notify Moderator
Network Error (tcp_error)
A communication error occurred: ""
The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time.
For assistance, contact your network support team.
NorthernLimits
Michigan
Posted: 05/03/12 06:22am Link  |  Print  |  Notify Moderator
Odd....I don't get the error trying to post in this forum but I get it when trying to post in the truck camper forum and the fifth wheel forum.
NorthernLimits
Michigan
Posted: 05/03/12 06:26am Link  |  Print  |  Notify Moderator
This is a test. When I removed the quote from my post in the truck camper section it worked.
NorthernLimits
Michigan
Dang....
Ok, so it happens when I quote FishPoet. LOL
 > Posting issue
