RV.Net Open Roads Forum: Tech Issues: Gen.
 > Gen.
Allan Miles
Home
Posted: 05/02/12 05:29pm Link  |  Print  |  Notify Moderator
I have a 96 32ft Bounder on a P30 chassie,it has a Onan 5000 Marquis gen.It will start and run about 15to 20 min.then cuts off with or without a load on it.I replaced the gas line on top of the gas tank last year,and the fuel line at the fuel pump up to the carb.Any help with this would greatly app.
Thank's Allan Miles
MNtundraRet
Bloomington, MN
Posted: 05/02/12 05:34pm Link  |  Print  |  Notify Moderator
It could be a bad printed circuit on the control board, or possibly a dirty connection to the control board.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
USARMYCW
TEXAS or somewhere in between
Posted: 05/02/12 06:00pm Link  |  Print  |  Notify Moderator
Mine was doing this and it turned out to be a dirty armature (sp).
CloudDriver
New Jersey Shore
Posted: 05/02/12 07:12pm Link  |  Print  |  Notify Moderator
Had a similar issue with our Onan 4kw gen a couple of years ago. Turned out to be the fuel pump. If your gen has a prime function on the switch at the gen, try to prime it after the gen quits. If you don't hear the pump buzzing after a few seconds replace the pump.
2003 Winnebago Minnie 24F - Ford E-450
 > Gen.
