RV.Net Open Roads Forum: 1/2 tons and 5th wheels. Trailer Life magazine article.
Search only in Tow Vehicles
 > 1/2 tons and 5th wheels. Trailer Life magazine article.
Page of 8
dodge guy
Bartlett IL
Posted: 05/08/12 05:45am Link  |  Quote  |  Print  |  Notify Moderator
DSteiner51 wrote:
I personally would rather tow a 5th wheel that inherently is stable that slightly overloads a 1/2 ton then a travel trailer that needs bandaids such as WDH and/or anti sway at 80% of rated Gross Weights. I think relying on bandaids is dumb, dumb, dumb.
OK, I`ll bite. what do you meen "bandaid"? I think that putting a hitch in the bed of a truck to tow a trailer is a bandaid and is dumb, dumb, dumb!
A top heavy load like a fifth wheel would actually be less stable!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
DSteiner51
Wooster, Oh
Posted: 05/08/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I wasn't expecting anyone to bite anything. I just stated an opinion based on 50+ years experience towing both semi trailers, gooseneck, and drawbar. There are hundreds of thousands of trailers being safely pulled with drawbar hitches without WDH or sway bars and possibly millions of semi's and other 5th wheels/goosenecks without WDH or sway bars and they are stable. To have to rely on WDH or sway bars is an indication something may be wrong so bandaids are used instead of fixing the problem.
To make a dumb statement like this is an indication that one has no idea.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
dodge guy
Bartlett IL
Posted: 05/08/12 11:47am Link  |  Quote  |  Print  |  Notify Moderator
I must be missing something? oh well!
Fordlover
Spring, Texas
Posted: 05/08/12 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone else notice how the 1500 Rams are pointing towards the sky, and the Ranger looks normal? My question is what kinda spring helpers does the Ranger have?
02 Ford Explorer 4.6 V8 4x4, prodigy and equalizer
07 Crossroads Sunset Trail ST19CK
and no payments
JN_B
Calgary, Alberta
Posted: 05/08/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Except there's one important thing you're missing...
Location of axles on a TT vs a gooseneck, reg trailer, semi, etc. (you'd think someone with "years" experience would notice this). almost ALL TT have axles that are close to or in the center of the trailer (I hope you understand what this does to the stability of a trailer...).
THIS...is the reason we need sway control & WDH.
BUT what do I know I've only been towing (a TT) for 10 years.
2003 GMC Sierra 1500HD SLT
2010 K-Z Spree 318BHS
MitchF150
Washington, the State
Posted: 05/08/12 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
phillyg wrote:
MitchF150 wrote:
Hummm.. You decide...
Mitch
Mitch, that particular combo appears to be overloaded. Pin weight is too much for that truck. This is a bad example.
I actually was being sarcastic in my comment and meant it to show what a 1/2 ton and a heavy 5th wheel looks like..
I know that combo in the pic I posted is overweight by just looking at it. (I found that pic from a Google Images search.)
I've seen 3/4 and even some 1 ton truck look like that towing some triple wheel jobs..
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
DSteiner51
Wooster, Oh
Posted: 05/08/12 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
You obviously have never seen a 5th wheel or goose neck trailer. If you have, notice where the wheels are? A TT should be carrying approx 10-15% of it's weight on the tongue a spread of 5% while a 5th/gooseneck should carry 15-25% on it's pin, a spread of double the TT. Know why? On my model 5th the axle placement is almost identical to the TT model.
Semi trailers are different. Sure one could put tandems axles on a 1/2 ton or any other pickup and move the trailer axles back.... at YOUR expense. Pickups pulling 5th wheels/goosenecks are more stable thus need no bandaids.
DSteiner51
Wooster, Oh
Posted: 05/08/12 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Timbrens. In my opinion the Timbrens made for the Ranger are too heavy.(1000lb) Debating whether I wanted to again try air shocks or airbags I decided to try Timbrens but the overload was minimal so I took a Saw Zall and cut two sides away on each Timbren to drastically reduce the load carrying capacity and get the same effect as airbags/shocks at low air pressure. The rubber is approx as thick as standard card stock paper on each side. Perfect! No help when empty but maybe a 200lb? help when loaded. No maintenance and yet slight increase in lift to keep the truck where I wanted it. Too many feed or fertilizer bags still make it squat to let me know when it gets heavy as we have no truck scales on the farm and loading ahead of the axle or behind makes a big difference as to the ability to carry a load.
JN_B
Calgary, Alberta
Posted: 05/09/12 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Go have another look at where the center of gravity is of a 5er and compare it to a TT. Most 5er's have a CofG ~5-6ft in front of the (trailer) axles. Not the case with a TT. This is part of the reason a 5er & gooseneck are (allegedly) more stable while towing (ie heavier tongue weight). But you probably didn't know that.
Oh yeah, and I'm talking length from the pin, not from the rear TV bumper.
DSteiner51
Wooster, Oh
Posted: 05/09/12 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
When I designed and built both bumper pull and gooseneck trailers I used 10-15% on bumper pulls and 15-25% on gooseneck trailers. Depending on the application the customer required determined the axle placement.
For example here is a photo of a general purpose gooseneck I built for myself. When loaded with 8 1200lb bales exceeding 15% would have heavily overloaded the truck. The CG was a the front edge of the front trailer tire.
When hauling a 4200lb tractor I could move the CG forward farther to get 20%+ and not overload.
When moving a 24ft X 32ft 2 car garage one best know where to put the CG by placing both the building on the trailer and the proper placement of the dollies to get the proper state permits. The state patrol escorts don't take too kindly to an overloaded unsafe situation. Sorry, I don't have a pict of it going down the road.
So no, I have no clue about axle placement of trailers. I'll let you teach me once you show me your qualifications on designing, building, and using trailers. Again, I stand by my first post on this thread.
Page of 8
