RV.Net Open Roads Forum: Travel Trailers: Dodge Ram 1500
 > Dodge Ram 1500
sch911
Rochester Hills, MI
Posted: 05/03/12 03:47am Link  |  Print  |  Notify Moderator
I am a Chrysler Engineer. Despite what others have said you'll have no problem towing that TT with your Ram 1500 Hemi. PM me if you would like to discuss further....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
eye8Ubutler
Maritime Provinces
Posted: 05/03/12 04:29am Link  |  Print  |  Notify Moderator
Bamacamper2012 wrote:
Sorry should have given more details. 2010 Dodge Ram crew cab 5.7L V-8 Hemi engine, tow package, electric brakes, 3.21 rear axle gear ratio and we want to pull a 6200 dry, 7000 loaded 35 ft Jayco Whitehawk.
STOP right there at "tow package"!
As far as dealers are concerned 'tow package' could mean as little as...a place to put the hitch assembly and nothing else!!!
A true "tow package" would be at least an uprated....cooling system and a rear axle ratio that is NOT 3.21?
There is a lot of help from 'posters' on here.
Regarding your wanting to pull a 35ft, your truck will be stuck in 3RD all day!!!
Please DO NOT mess about trying to adapt that TV, start again with a different TV if you want that 35ft as ya RV of choice!!!
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
eye8Ubutler
Maritime Provinces
Posted: 05/03/12 04:35am Link  |  Print  |  Notify Moderator
ARE YOU ON SOMETHING MATE!
There is NO way Mr Chrysler Engineer, that TV is going to give a pleasant experience towing a 35ft RV!!!!!!
.....I forgot to mention, the Dodge 1500 from around 2010 onwards..."MUSHY" rear coils...will NOT HELP EITHER!!!
That is why from 2013 the Dodge 1500 is having a "Band-Aid" made available from the 'factory', sorry Mr Engineer you would call it a 'rear air suspension assist'...I call it having put rear coils on a North American Pick Up a big BOO BOO!!!
* This post was last edited 05/03/12 05:22am by eye8Ubutler *   View edit history
markandkim
Swansea, MA.
Posted: 05/03/12 04:38am Link  |  Print  |  Notify Moderator
I've got a ?
Why doesn't it say "Dodge" anywhere on the new trucks?
I beleive Fiat wants it gone.
Retired Navy
2012 Ram 1500 Quad Hemi
2010 Amer-Lite 255BH
2004 Tracker 175 bass boat
Bamacamper2012
Birmingham, AL
Posted: 05/03/12 05:36am Link  |  Print  |  Notify Moderator
Our truck is auto, 2 wheel drive
sch911
Rochester Hills, MI
Posted: 05/03/12 06:36am Link  |  Print  |  Notify Moderator
Ha.. Ha.. Ha..
Not falling for that dribble.
Perhaps you should consider decaf from now on.
hopeulikit
Snellville, GA
Posted: 05/03/12 07:39am Link  |  Print  |  Notify Moderator
I registered for this forum just to put my 2 cents in. I run a '09 Ram 1500 CC Hemi with 3.92 gears. The truck started life with 3.21's but they killed the towing capability. With that one change and a properly adjusted weight distribution system (along with two old school friction sway controllers) the truck pulls fine, not great but fine. I'm pulling 7,000lb loaded. No exact idea of tongue weight but adjusted properly, my helwig helper springs don’t even touch the stops.
One last point, the only difference in towing limits for the 1500 are the rear-end ratios. There is no "towing package" for the '09 1500 as it already has the separate trans cooler and HD cooling.
Believe me, I worry about everything and I've researched this to no end. The gear switch is expensive but for me, worth every penny
LAdams
Northern Illinois
Posted: 05/03/12 08:05am Link  |  Print  |  Notify Moderator
Thread has gone way off topic and has degenerated badly - time to close this one
Moderator - TT Forum
 > Dodge Ram 1500
