RV.Net Open Roads Forum: inverter / 12 v power help
LowRyter
OKC
Posted: 05/02/12 07:12pm Link  |  Print  |  Notify Moderator
I'd like to use by LCD TV off the battery, as well as other things like a lap top. All my outlets are 110 and my lights are 12v.
How can I get power to the TV? All the cheap inverters ($50) have alligator clips to the battery. That's a long ways to fish a cable.
What about my lights? Can I hook and inverter to one of them?
Sorry, but I really don't know how these things are wired. This sounds like a dumb question, so sorry.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
2oldman
Wilson Creek WA
Posted: 05/02/12 07:15pm Link  |  Print  |  Notify Moderator
Start here...
Don Rowe site Inverter FAQ
Inverters by Phred
smkettner
Posted: 05/02/12 07:24pm Link  |  Print  |  Notify Moderator
I power my tv, dvd, laptop and charge small items with a Go Power 300w sine wave inverter.
I mounted the inverter behind the fuse-breaker panel. 12v connects to the main battery feed to the panel. 120v is wired into the entertainment area circuit with an automatic transfer switch. The wiring is very straight forward if you have done any home wiring before. The Go Power 300w has a provision for a remote power switch so with the touch of a button I have instant power.
GP 300w SW $160
Xantrex 15 amp switch $49
So all in maybe $250-$300 for self install.
Morninstar also makes an excellent 300w inverter called SureSine.
675 watts solar
skipnchar
Topeka or somewhere else
Posted: 05/02/12 07:25pm Link  |  Print  |  Notify Moderator
Wiring to your lights are probably not heavy enough to run an inverter of any size at all. One easy (no install) method is to use those alligator clips to connect directly to the battery and transport the power at 120 volts (it travels easily at 120 volts but not well at all at 12 volts. You could probably wire your inverter directly to the positive and negative leads at the converter. If you mount the inverter close to the converter it would simplify things a lot.
KD4UPL
Swoope, VA
Posted: 05/02/12 07:33pm Link  |  Print  |  Notify Moderator
Inverters require heavy, short wires connected directly to the battery. Don't forget a fuse in the positive line. Your RV's light circuits are way too small.
If your TV uses about 150 watts and your laptop about 150 watts you will be pulling over 30 amps from the battery.
Queens Carriage
Treasure Coast, FLorida
Posted: 05/02/12 08:37pm Link  |  Print  |  Notify Moderator
road trucker .com 12v tv/dvd players
dahkota
Washington, DC
Posted: 05/03/12 05:15am Link  |  Print  |  Notify Moderator
This might not be the most efficient way to do it, but I use the 300W inverter that I got for my car cigarette lighter. I plug it into the tt 12V outlet. My tv (vizio led) uses 20W so it is barely a drain on the battery. My laptop can also be run off the inverter, though I don't do it at the same time. It has worked for me for over a year with no problems.
2008 Ford F250 diesel
2013 Keystone Sprinter 277RLS
ryanallie1
Magalia, Calif
Posted: 05/03/12 08:35am Link  |  Print  |  Notify Moderator
HI All.
First of all, for Small Loads, you do not have to directly wire your Inverter to the Battery Bank.
Espically with todays very low power LED TV's. We have about 7 or 8 different sizes of Inverters. And not one of them is hard wired to the Battery Bank.
For heavier loads it is a good idea, so is investing in larger size wire..
We have just been using "Cig Lighter Outlets" and "Power Ports" for many many years now. And not so much as one problem.
And I have never bothered to change any wire sizes either. A good way to find out what your item uses for power, that you want to use, is use a Kill-A-Watt Meter.
Everything that we use with our Inverters is safe with the wire size that we already have. I do have one Larger Inverter, that if I wanted to use, I can hook that one up diredtly to the Battery Bank, and then run an extension cord to power what I want to use.
We just have never found the need to "Hard Wire" in an Inverter in the 45+ years as RV'ers. But that is just us.
Everything that we do run, works perfectly off of any "Cig Lighter Outlet" or a "Power Port"
So it all just breaks down to what you want to run off of an Inverter, and how much power it pulls.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
U.P. BLDR
Upper Peninsula of Michigan
Posted: 05/03/12 01:24pm Link  |  Print  |  Notify Moderator
I do it the poor mans way, Finlander engineering it's called around here. Inverter wired to battery, double male cord that plugs into the inverter outlet and the other end to a wall outlet to power up the trailer. What I actually do is unplug the converter and plug my inverter cord into that. You HAVE to shut off power to the converter. The automatic switching is a better way to go though, easy to do and not expensive AFAIK.
1981 Sunline 17 1/2SB - under construction
2003 Toyota Tundra SR5 TRD 4x4 4.7lt
LowRyter
OKC
Posted: 05/03/12 04:36pm Link  |  Print  |  Notify Moderator
ryanallie1 wrote:
HI All.
so Bill, where do you wire your inverters in, if not to the battery bank? this is precisely my question. how and where do I hook up the inverter? just for tv and computers and cameras.
