RV.Net Open Roads Forum: thermostat upgrade issue
csmithtrw
Green Bay, WI
Posted: 05/02/12 08:05pm Link  |  Print  |  Notify Moderator
following the advice from many others, I am upgrading to a digital thermostat. I purchased a unit at Menards and after failing to first time, did some more homework and attempted again tonight improving my results by half. The furnace worked like a charm. The AC unit no so much. It kicks on but the blower does not function. I connected only the high fan wire and left the low fan blank. I also did not connect the 7.5v lead to anything. This is going in a 2011 Puma 25BH and the new thermostat is a LUX DMH110.
One question I had was other more expensive units say they can run off of battery alone and do not need 24v supplied. This unit does not say that, so I'm wondering if that will matter. I called LUX directly and was told the unit is not made for an RV so they were of little to no help. I'm hoping that many of your are smarter than I am and can offer some suggestions.
Thanks
Old-Biscuit
Across the USA
Posted: 05/02/12 08:36pm Link  |  Print  |  Notify Moderator
'Y' terminal....connect yellow wire (A/C)
'W' terminal....connect white wire (Furnace)
'G' terminal....connect blue wire (high fan.......orange wire/low fan tape off)
'RH-RC' terminals....(jumper together) connect black wire (ground...common)
Red wire (7.5+) not used...tape off
And for the blower to operate from furnace control you have to select 'gas' on jumper on back of circuit board ( should be printed on board).
Two new AA batteries and should be good to go.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Chris Bryant
DeLand, Florida, USA
Posted: 05/03/12 05:10am Link  |  Print  |  Notify Moderator
The high fan and low fan must both be connected for the high fan to operate on the DuoTherm analog system.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
csmithtrw
Green Bay, WI
Posted: 05/03/12 05:44pm Link  |  Print  |  Notify Moderator
so if I dont have a toggle switch, can I tie the low and high fan together?
csmithtrw
Green Bay, WI
Posted: 05/03/12 06:38pm Link  |  Print  |  Notify Moderator
answered my own question. Works like a charm. Thank you Chris for your input.
LAdams
Northern Illinois
Posted: 05/03/12 06:40pm Link  |  Print  |  Notify Moderator
Chris stole my comments Both leads must be connected for hi fan to work
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
