RV.Net Open Roads Forum: Fifth-Wheels: cost of new hitch
 > cost of new hitch
kdavenport
arkansas
Posted: 05/02/12 08:14pm Link  |  Print  |  Notify Moderator
OK, so we finally purchased a Jayco 26.5, now we need the hitch placed in the F250, the dealer where we purchased the 5er obviously wants to install it, what would be a reasonable cost to allow him to do that? Would it be less expensive to go to another place to have it installed, we drive a f250 diesel, weight and everything is in line. thanks kld
jalichty
Lander, Wyoming 82520
Posted: 05/02/12 08:29pm Link  |  Print  |  Notify Moderator
I think I paid a little less than $300 to get our old hitch put in the new truck. It is a Reese 15,000# with a hitch weight of 3,750# and a slider, if that makes any difference. They took the old rails and put them in the new truck. Had some kind of kit so they didn't have to drill too many, if any, holes in the frame. The slider hitches are a tad bit expensive, more so than the regular ones. Did you get the HT fifth-wheel. What model 26.5 did you get?
John A. Lichty
John3872
Iowa
Posted: 05/02/12 08:52pm Link  |  Print  |  Notify Moderator
It took me about 3 hours to install my frame brackets, drill the holes for the rails and install the rails. I would think reasonable would be 3 hours times whatever their hourly shop rate is.
2003 Chevy 2500HD Duramax Crew Cab
2009 Palomino Sabre 30RLDS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
therink
Rochester
Posted: 05/02/12 09:08pm Link  |  Print  |  Notify Moderator
X2- it took me 3 hours. I figured I saved $300. Shop online for lowest price for same hitch dealer is offering and have them match it plus about 3 hrs labor.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
Artemus Gordon
Redding California
Posted: 05/02/12 09:55pm Link  |  Print  |  Notify Moderator
I am incapable of installing the rails. Last month I bought a Curt Q24 and a rail kit. Installation was $285.00 and Curt Hitch cost me about $600.00 online. My truck was a "chassis truck" so rail install was not easy as standard pickup.. Also had to cut into plastic bed liner. My regular mechanics did it! Very happy...
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
kdavenport
arkansas
Posted: 05/03/12 06:08am Link  |  Print  |  Notify Moderator
It is a rear kitchen model RKS, and I do not have a hitch.I am going to have to purchase it from the dealer along with installation, and I think a slider is appropriate, so would around 1000$ installed be appropriate? I can always buy the hitch and install it but letting them do it seems simpler if the cost is somewhat similar.
bigdon68
Churchville, Maryland
Posted: 05/03/12 06:55am Link  |  Print  |  Notify Moderator
It is not that difficult to install yourself. Just do the measurements, drill the holes and bolt in the rails. I did that for my AIRSAFE hitch and it was a pretty straightforward job.
Good Luck.
Bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
MY PICTURES
boston blacky
Gatineau Quebec Canada
Posted: 05/03/12 07:08am Link  |  Print  |  Notify Moderator
Greetings;
I figure you need a hitch first. Got hitch. If the place where you purchased it is willing have them install it. Should the dealer have the skills and knowledge - that is also and option. Either or - the installer should give a warranty and adjust (level off) the hitch so it is set inline with the 5er.
Ask the installer to also hook up your brake controller and get them to test and set it properly as well. My opinion.
BOSTON BLK
phillyg
Front Royal, VA
Posted: 05/03/12 07:12am Link  |  Print  |  Notify Moderator
Since you indicated you needed a slider, then I assume you have a short bed truck. If so, an automatic slider similar to Superglide would be your best bet, but wow, they are expensive. Regardless, first decide what hitch you need, then price them all over the internet and at local installers, and take that best price back to your dealer and ask for the same. Get them to provide and instal the controller also, perhaps on their dime. After all, you're buying the FW from them.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
jetenbu
Southeast Texas
Posted: 05/03/12 09:36am Link  |  Print  |  Notify Moderator
I had my hitch installed at a place that does them all the time, not at an RV dealer. I think I got a PROPER installation by doing this. I would highly recommend you do the same. Hitch markup can be pretty high at RV dealers but not so much at a place that specializes in hitches. Just my humble opinion....
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
 > cost of new hitch
