RV.Net Open Roads Forum: General RVing Issues: First Time With No Hookups...
 > First Time With No Hookups...
Page of 8
bikendan
Napa, Cal.
Posted: 05/02/12 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Dry Camping takes some research and some self-restraints.
those who are used to having hookups, don't have an idea what changes have to be made, especially in water and battery usage.
living in California, nearly all our state park campgrounds have no hookups of any kind, so you learn to dry camp.
with our hybrid, we have 2 12v deep cycle batteries, a Honda 2000 and years of popup camping experience. so we are used to not using the furnace a lot, taking Navy showers, using lanterns and so on.
beginning to dry camp takes preparation and learning new attitudes.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
silvercorvette
Anderson SC
Posted: 05/02/12 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
I got my first RV used back in the early 1980s so it was probably a mid 70s model. One of the many things it did not have was a battery, there was no water pump you pressurized the tank with air. If you wanted heat you had to light a match and hold your finger on the pilot light till it got hot enough to stay lit,. The camper was so small you did not need a fan to spread the hot air around. But one night I remember well from about 30 years ago was when I was hooked up in a cement parking lot at the Grand Canyon. It was late September with shirt sleeve weather during the day. But as soon as the sun went down it dropped to below freezing. I was a cuddled up with my G/F in the back and he heater was keeping us toasty warm. Sometime in the middle of the night we both woke up freezing, the wind had blown out the pilot light and the safety shut off turned off the gas.
I spent what seemed like an eternity on my knees holding the button waiting for the thermocouple to warm up enough to take my finger off the button. It only happened once but even with the extra work required to get the heater running it was nice to have a camper that did not depend on battery power for heat. The problem is these large campers need fans to move the hot air around.
With my current setup I have 2 batteries in my truck and one in my camper which makes me confident I won't have to worry about running out of power
I once read that studies have shown that most accidents occurr within 10 miles of home, so I moved
1L243
Astoria, Oregon
Posted: 05/02/12 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Your going to need a second battery. Set your thermostat to 52 degrees and take extra blankets.
30 gallons a day...WOW! If you run your water pump dry it will not last very long...
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
silvercorvette
Anderson SC
Posted: 05/03/12 12:30am Link  |  Quote  |  Print  |  Notify Moderator
I missed the 30 gallon a day part on first read, I am only one person with 2 dogs and won't use that much in a week.
I buy a case of bottled water, I think there are 24 or 30 (maybe 36) 12 ounce bottles to a case and a case that last me and my dogs over a week. I do drink a lot of soda but I fill up the glass with ice cubes made from bottled water.
For showers I only use a few ounces of water to get wet then shut it off and soap up, Then only use a few ounces to rinse. For washing dishes I put a couple cups of soapy water in one sink, and a few cups in a rinse sink for a total of a little over a quart. If I don't have many dishes I may do the breakfast and lunch dishes together. 30 gallons in one day is mind boggling.
bartlettj
Forest Grove, OR
Posted: 05/03/12 02:55am Link  |  Quote  |  Print  |  Notify Moderator
I dry camped in a popup for two weeks a couple of years ago, while using the furnace once in a while. The key was careful power management. First of all, I added a second battery and a quality volt meter. I had two group 27 deep cycle batteries and never ran dry. I was using my TV to charge them up as I drove every couple of days, though, but they never got fully recharged after I left home with them. Always leave home with them fully charged. Second, I acted like I was camping in a tent and only ran the heater to take the edge off in the morning and evening. I used little LED tap lights and went to bed at sundown. I used my water pump but only about 5-10 gallons a day. I shut down all the other 12v appliances by pulling the fuse or shutting off the switches, so everything that could ran on propane. So shut off the stereo, microwave, fridge fan, whatever else is set up to draw 12v.
M GO BLUE
Southgate, MI
Posted: 05/03/12 05:46am Link  |  Quote  |  Print  |  Notify Moderator
40F or above we turn onthe hear about 1 hour before we go to bed, turn off right before we go to bed and put an extra blanket on the bed and then turn heat back on in the morning...
38F or lower we turn the thermostat to about 55-60, throw an extra blanket on the bed and are good for the night...we need the furnace at this temp to keep the basement from freezing the water lines
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
WandaLust2
TN
Posted: 05/03/12 06:20am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like they're acting as though they were home. They haven't yet learned to conserve. We don't have a generator so when dry camping somewhere between point A and point B, we conserve. We turn the hot water on propane to wash up and do any dishes. Then shut it off. I have a kerosene lantern for light rather then use the TT's lights which eat the juice. The fridge auto switches to Propane when on the road. We will use heat but haven't drained the battery yet in only one night. We use heavy quilts and fleece sheet sets. Their water usage blows me away. 30 gallons a day? They must be taking showers daily and letting the water run. In time they will learn how to conserve.
WandaLust. Retired. Middle TN
Heartland 2011 NorthTrail 28BRS
1993 Ford Dutchman Class-C
K3WE
Missouri
Posted: 05/03/12 06:27am Link  |  Quote  |  Print  |  Notify Moderator
On one hand, killing a battery overnight with heat is not unusual.
On the other hand, your battery might be weak, and/or not getting a good charge (as many others have said).
I would also like to throw out that your battery might be old and unhealthy.
We usually do not have a problem getting through the night with a good battery.
Conversely, with two abused batterys, we did NOT make it through the night.
beemerphile1
I'm 57, I'm not a
Posted: 05/03/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
It is all about conservation. When camping without hookups you cannot act like you have unlimited supplies.
Our small trailer holds 11 gallons of water and we can go for two days on that one tank. That includes all bathing and consumption.
Answer the questions you've been asked. Are they charging with the factory converter, what brand and model? Are they charging from the charge port of a portable generator?
Ignore the idiot lights, they need a digital meter and need to learn its use. Here are the voltage readings of a battery with no load on it;
Read these articles;
http://www.marxrv.com/12volt/12volt.htm
http://www.batteryfaq.org/
http://www.windsun.com/Batteries/Battery_FAQ.htm
Camping 'off the grid' takes some extra education and effort but it is well worth it. The best campsites don't have hookups.
- Soren Kierkegaard
qtla9111
Monterrey, Mexico
Posted: 05/03/12 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Apart from conservation, I also vote for a weak battery. Also, clean and tight cable connections. Be sure to check water levels too.
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
Page of 8
