RV.Net Open Roads Forum: Height from bed rails to bottom of 5th wheel
 > Height from bed rails to bottom of 5th wheel
gmcsmoke
Butler
Posted: 05/03/12 04:52am Link  |  Print  |  Notify Moderator
I thought the factory was supposed to fix your height issues over a year ago.
tvman44
Southwest Louisiana
Posted: 05/03/12 05:32am Link  |  Print  |  Notify Moderator
The general consensus has always been min 6".
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
OldGreaser
South Texas
Posted: 05/03/12 07:20am Link  |  Print  |  Notify Moderator
I have 7" and hit once due to driver error involving a 'shallow' ditch. The dent's not a bad one but it's enough to be a constant reminder.
M GO BLUE
Southgate, MI
Posted: 05/03/12 05:35am Link  |  Print  |  Notify Moderator
Hard to get the 6" minimum with the new heavy duty trucks these days...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
Texas Two Steppers
Beaumont, TX
Posted: 05/03/12 05:43am Link  |  Print  |  Notify Moderator
I have 7" perfectly parallel with truck bed.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
phillyg
Front Royal, VA
Posted: 05/03/12 07:02am Link  |  Print  |  Notify Moderator
6" here, too. Have had one occasion where there was less than 1" left on one corner during a tricky backup maneuver, so more is best IMHO.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
mobilcastle
OH
Posted: 05/03/12 08:22am Link  |  Print  |  Notify Moderator
6" good 8" better. I have about 7"
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
ACZL
UPstate,NY
Posted: 05/03/12 10:07am Link  |  Print  |  Notify Moderator
Just keep in mind that you should NOT go over 13' 6" in overall height. 5ers don't like bridges if they are over that!. Doesn't help matters any when truck mfrs keep putting larger tires in them.
2003 F250 SD,CC,4x4,SB,AT,Lariat,6.0PSD
2006 Cedar Creek Silverback 33 LBHTS "Custom"
Member of The Cedar Creek RV Club
"Creekin' in the Summer"
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
