RV.Net Open Roads Forum: Class A Motorhomes: leveling
 > leveling
rstuck
home
Posted: 05/02/12 09:10pm Link  |  Print  |  Notify Moderator
Is it safe or advisable to level a class a with the toad attached, I have seen it done but wonder if it might put to much stress on the tow bar or frame. Any imput would be appreciated
royST
ann arbor
Posted: 05/02/12 09:18pm Link  |  Print  |  Notify Moderator
Welcome to the forum!
Yes, it's pretty safe to level your motorhome even with the toad still attached to it. You may want to check out this other thread in this forum for more info on this: https://rv.net/forum/index.cfm/fuseactio........d/tid/22634831/srt/pd/pging/1/page/1.cfm
hottubkid
SCHAUMBURG,IL
Posted: 05/02/12 09:30pm Link  |  Print  |  Notify Moderator
Depends on the tow bar. Mine adj up and down. Well with in limits
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
jimrose
Hoffman Estates, IL
Posted: 05/02/12 09:39pm Link  |  Print  |  Notify Moderator
We do it all the time with no problem.
Jim
01 38' Holiday Rambler Endeavor DP Cummins 330 HP ISC
04 Ford Explorer MG Brake System Wireless Lights
fcooper
Richmond Hill, Georgia
Posted: 05/02/12 09:41pm Link  |  Print  |  Notify Moderator
When I level with the toad still attached, I make sure that the toad transmission is still in neutral as it will need to move a little as the motorhome goes up to level and again when the jacks are retracted.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
FIRE UP
Ramona, CA. USA
Posted: 05/02/12 10:44pm Link  |  Print  |  Notify Moderator
rstuck,
Sure you can. What you have to take into consideration is the amount you'll need to raise the rear of the coach, if needed, to get it level. And the only reason you need to think about it is because if, you decide to disconnect while your level and you're at some strange angle, you might have a bind on the tow bar. But, tow bars are made to pivot, up and down. So, you should have no issues leaving it connected and leveling.
Scott
Scott and Karla
SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
fredaevans
Ashland, Oregon
Posted: 05/03/12 07:43pm Link  |  Print  |  Notify Moderator
I'll be the 'contrarian' (sp?)here. As a 'personal,' and I'll assume a general norm, your tow bar should be going straight at the MH hitch ball. If you put down the jacks and give that an 'upward slope' the disconnect can turn into a total pain where one sits. In down the road mode (assuming a flat parking pad here) everything is in alignment. You have to disconnect sooner or later ... sooner is better.
That way you can adjust the MH anyway you want and 'toad' couldn't care less.
fae
 > leveling
