RV.Net Open Roads Forum: Carbon monoxide poisoning a real threat in TT?
 > Carbon monoxide poisoning a real threat in TT?
Big Juan
Salt Lake City, Utah
Posted: 05/03/12 01:56am Link  |  Print  |  Notify Moderator
Is carbon monoxide poisoning a real threat in modern travel trailers?
Growing up my dad refused to run the heater in the trailer (1969) for fear of carbon monoxide poisoning. When we finally upgraded to a new trailer (1994) he used the heater sparingly and opened the windows for proper ventilation which seemed to make it colder!
Now that I am a father of a young family and have my own new trailer (2012) I have concerns of my own. Are my concerns really warranted? I was told the fuel burning appliances all vent outside so it is moot unless a catastophic failure occurs. Should I close the windows and enjoy the heat and trust the carbon monoxide detector? Is one vented window enough or should they all be opened?
Thanks in advance!
2012 Jayco Jay Flight 26BH
2004 1500 Yukon XL SLT
10K Equal-i-zer
King, Queen, 3 Princesses
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 05/03/12 02:10am Link  |  Print  |  Notify Moderator
Keep your windows closed and enjoy the heat, trust the carbon monoxide detector and use the test button before each trip. I think your overly concerned, especially with a 2012 trailer.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
fla-gypsy
North Florida
Posted: 05/03/12 03:50am Link  |  Print  |  Notify Moderator
+1
eddie3260
Florence, al
Posted: 05/03/12 04:03am Link  |  Print  |  Notify Moderator
I thought the furnace recieved it's make up air from outside the camper. If so, not much chance of a CO build-up. The stove and oven do receive make up air from inside the camper. So if the Oxygen levels start getting low, you will have imcomplete combustion and start producing CO. I crack a window when cooking. If using gas for hot water or heat, I don't do anything.
dahkota
Washington, DC
Posted: 05/03/12 04:23am Link  |  Print  |  Notify Moderator
Your father was smart. But now CO detectors are commonly available and should be installed in every trailer (and every house). Make sure you have one, make sure it works, and you should be fine.
Just remember:
"The gas sensors in CO alarms have a limited and indeterminable life span, typically two to five years. The test button on a CO alarm only tests the battery and circuitry not the sensor. CO alarms should be tested with an external source of calibrated test gas, as recommended by the latest version of NFPA 720. Alarms over five years old should be replaced but they should be checked on installation and at least annually during the manufacturers warranty period."
2008 Ford F250 diesel
2013 Keystone Sprinter 277RLS
Lantley
Ellicott City, Maryland
Posted: 05/03/12 04:28am Link  |  Print  |  Notify Moderator
CO from furnace is no more of a threat in your RV than it is in your home. All new RV come with CO detectors
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
pianotuna
Regina, SK, Canada
Posted: 05/03/12 04:29am Link  |  Print  |  Notify Moderator
Hi,
The risks in a modern travel trailer may be highest from generator use. I will not sleep with a generator running.
I do not worry about stove use.
As others have said, the furnace and water heater use outside air.
So does the fridge.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Mark and Linda
Smyrna, Tennessee
Posted: 05/03/12 04:41am Link  |  Print  |  Notify Moderator
If concerned about running heat at night and you have shore power, buy a ceramic heater. We used one....set the temp where we want...use the tt heater for backup.
Tvov
CT
Posted: 05/03/12 05:23am Link  |  Print  |  Notify Moderator
I always vent our TT. Open the window over the kitchen sink 1/2 to 1 inch, and leave the vent fan open over the bathroom about an inch. Biggest reason is to have fresh air in the camper (family of four), but it also cuts down on condensation. As to CO my camper has a CO detector that I check regularly, but I don't fully trust detectors, I've seen too many fail.
By the way, good job to your Dad! Being concerned about CO back then seems unusual and very smart.
2008 F-250 CrewCab 5.4L,
CincyGus
Cincinnati
Posted: 05/03/12 05:39am Link  |  Print  |  Notify Moderator
X2- I vent to help prevent the condensation from heating inside/cold outside but it has the added benefit of helping prevent the CO issue. I test all the detectors prior to each trip as part of my before we leave checklist.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
