RV.Net Open Roads Forum: Carbon monoxide poisoning a real threat in TT?
 > Carbon monoxide poisoning a real threat in TT?
Turtle n Peeps
California
Posted: 05/03/12 11:12pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Turtle,
The dust in the air can "burn" in the heat exchanger. If a person is "sensitive" to such items it doesn't take much to cause them to have an asthma.
I think they might have even better luck with oil filled heaters.
That make sence but Lill was talking about a flame which I did not get? I guess they could be talking about heat exchanger or fan dust?
outside the fire"
mowermech
Billings, MT
Posted: 05/04/12 06:33am Link  |  Print  |  Notify Moderator
Lilliputian wrote:
We use a ceramic heater. Not because of CO poisoning, but because we have kids with asthma, and the furnace fire just bothers them. In any case, it supplies a very generous amount of heat for our 26 foot trailer, even in the "master bedroom" that has pocket doors on either side of a center wall for the swivily TV thingie (yes, that's the technical term for it). We do leave those pocket doors open, of course.
I think that 2 CO detectors is a good idea. Actually testing a CO detector is hard to do. When you press the button, you're just testing to see if the noise maker and battery are functioning. To test a smoke detector, you need to put smoke under it and see if it goes off. Likewise, to test a CO detector, you need to expose it to CO and see what happens. Since your CO detector is a part of your trailer and can't be removed to, for example, your garage while a car is running, you never really know for sure if it's functioning well. Having two makes things safer.
I have no doubt that SOMETHING is bothering your children, but I doubt it is "the furnace fire". As mentioned, the fire is completely contained in the heat exchanger. The furnace draws in outside air for combustion, and vents the exhaust to the outside. The air in the trailer goes over the outside of the heat exchanger and circulates inside the trailer.
I suspect your furnace needs to be cleaned. The dust, dirt, mouse nests, etc. are probably what is awakening the sensitivity in your children.
IF the heat exchanger is cracked, (a rare but not unknown occurrence), combustion by-products could be entering the trailer air. If that is the case, the furnace should be replaced.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Turtle n Peeps
California
Posted: 05/04/12 11:35am Link  |  Print  |  Notify Moderator
That is what I was thinking Mower. Could be something as simple as a good cleaning or could be something as serious as a cracked heat exchanger. Either way, IMHO it should be checked out.
pianotuna
Regina, SK, Canada
Posted: 05/04/12 01:12pm Link  |  Print  |  Notify Moderator
Hi,
Something I've never understood is that RV furnaces do not appear to have an air filter. At least not one that I can service or replace.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
