RV.Net Open Roads Forum: Carbon monoxide poisoning a real threat in TT?
 > Carbon monoxide poisoning a real threat in TT?
mowermech
Billings, MT
Posted: 05/03/12 10:04am Link  |  Print  |  Notify Moderator
I agree with Bob Landry.
I grew up with coal furnaces, wood stoves, oil heaters, and gas kitchen stoves, NONE of which used outside air for combustion.
My first RVs had propane wall heaters that had outside exhaust, but inside combustion air, AND had propane lamps on the wall, with NO CO detectors!
In fact, there were no detectors of any kind!
How DID we survive!
Actually, quite well, thank you.
Yes, the danger is real. But, the risk is minimal. The most common thing in a modern RV would be a crack in the heat exchanger of the furnace (just like the gas furnace in your home!) It would appear that that is a very UNcomomon occurrence, though.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
evanrem
WI
Posted: 05/03/12 10:53am Link  |  Print  |  Notify Moderator
I switched to a electric heater when we have shore power. The furnace would wake me up throughout the night every time it would kick on. Plus it's cheaper to run. As for threat of gas poisoning I think it s been covered.
Turtle n Peeps
California
Posted: 05/03/12 11:14am Link  |  Print  |  Notify Moderator
How DID we survive!
Well said Mower. I'm sure I'm not the only one that remembers propane mantel lamps in our trailer. Unvented at that.
outside the fire"
Francesca Knowles
Port Hadlock, Washington
Posted: 05/03/12 12:55pm Link  |  Print  |  Notify Moderator
CO poisonings from propane appliances are vanishingly rare. Nearly all above-ground CO-related deaths are a result of fossil fuel (gas, diesel, charcoal) poisoning, and as pointed out above generators are a growing problem source.
Your neighbor's generator fumes getting sucked in to your rig pose a greater threat than a (properly functioning) propane appliance of any kind.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
fordsooperdooty
Posted: 05/03/12 01:53pm Link  |  Print  |  Notify Moderator
We have always used a plug in 120 volt CO/explosive gas monitor AND a ceiling battery powered CO monitor. Same with smoke detectors. Small price to pay for a lot better protection and peace of mind.
Same with our house.
WrighSJ
Upstate NY
Posted: 05/03/12 06:49pm Link  |  Print  |  Notify Moderator
I agree with Skipnchar...test your CO detector and make sure your furnace, water heater and fridge are burning properly.
I had a bug crawl up the air/gas tube in my water heater on our last outing. It caused the heater to burn poorly and the side of the TT was covered in soot by the time I noticed it. I'm sure it was making CO...and thank god it's in a sealed outside compartment.
2006 GMC 2500HD CC 4x4 4.10
2010 Zinger 31SB, Equal-i-zer, Prodigy, Honda eu2000i
Chuck&Gail
In the Colorado Mountains
Posted: 05/03/12 09:16pm Link  |  Print  |  Notify Moderator
As several have said, there are dangers, but not from the RV furnace, at least no more than in a home.
But generator exhaust has been known to get into RV's and kill. Also you really should open a window or vent a bit when using the stove or oven, especially if used for extended periods of time.
One added point. Some folks use catalytic stand alone heaters when boondocking. These heaters, at least all I've seen, very clearly warn the user to leave the window open, as several people die every year by using those types of heaters in an enclosed space.
Have fun out there!
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Lilliputian
DFW area, Texas
Posted: 05/03/12 09:42pm Link  |  Print  |  Notify Moderator
We use a ceramic heater. Not because of CO poisoning, but because we have kids with asthma, and the furnace fire just bothers them. In any case, it supplies a very generous amount of heat for our 26 foot trailer, even in the "master bedroom" that has pocket doors on either side of a center wall for the swivily TV thingie (yes, that's the technical term for it). We do leave those pocket doors open, of course.
I think that 2 CO detectors is a good idea. Actually testing a CO detector is hard to do. When you press the button, you're just testing to see if the noise maker and battery are functioning. To test a smoke detector, you need to put smoke under it and see if it goes off. Likewise, to test a CO detector, you need to expose it to CO and see what happens. Since your CO detector is a part of your trailer and can't be removed to, for example, your garage while a car is running, you never really know for sure if it's functioning well. Having two makes things safer.
Turtle n Peeps
California
Posted: 05/03/12 10:42pm Link  |  Print  |  Notify Moderator
Why would a sealed combustion chamber and fully vented furnace bother anyone inside a trailer?
pianotuna
Regina, SK, Canada
Posted: 05/03/12 10:53pm Link  |  Print  |  Notify Moderator
Hi Turtle,
The dust in the air can "burn" in the heat exchanger. If a person is "sensitive" to such items it doesn't take much to cause them to have an asthma.
I think they might have even better luck with oil filled heaters.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
