outdoordb
Maryland
I'm kicking around the idea of putting a cold air intake on my 03 Suburban. I hear people talk about added HP and MPG. Are they worth it, will I see a differance, will they harm the engine ? If it is a good mod what brand, K&N, oiled, dry ? Thanks for the input
fla-gypsy
North Florida
IMO you should save your money and buy a few more gallons of gas as you will not acheive either goal by doing it.
shum02
Burlington ON CDA
Put one on my 4.6L '98 F150. Waste of time and money and now I have a filter I pull off once a year, wash, dry and then re-oil - takes a whole afternoon.
Saw absolutly no improvement including sound with it's installation.
As usual YMMV.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
Rich&Yvonne
Lake Park, Florida
shum02 wrote: Put one on my 4.6L '98 F150. Waste of time and money and now I have a filter I pull off once a year, wash, dry and then re-oil - takes a whole afternoon.
As usual YMMV.
X2
Except mine was a 2005 F150. I installed a Volant dry filter
dodge guy
Bartlett IL
As usual YMMV.
A whole afternoon?! I have one and it takes a few minutes then a couple hours to dry.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
eHoefler
ozark mountains
Any thing more than a good tune-up and maintenance, is a waste of time and money. More power and gaining mileage is an oxymoron. Power requires fuel.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
Trail-Mate
Frederick, MD
They can help but only if you can also increase the exhaust side flow. on a 2003 I doubt you improve it much since the factory already did. On older vehicles they can and do help if Exhaust, Intake and Cats are changed and have improved flow over the stock Parts. I think you would have to go back to about 1996 or older setups to see the benefits on these changes. A good Tuner may be more of a benefit because it can adjust the timing, Fuel mixture. Most new cars and trucks are tuned Lean from the factory to reduce emissions. Lean mixture rob power and affects efficiency. A Proper Tune and mixture should help HP and economy.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
omatty
nashville, tn
you'll see a diffrence if put on a dyno. however you will have no "seat of the pants" feeling and an increase in mpg is not likely. However an intake and exhaust combo will change that.
ib516
Up here!
A CAI is unlikely to add any power or mpg.
Read this, it's been tested:
LINK
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
ScottG
Bothell Wa.
You already have a CAI frm the factory.
Scott, Grace and Wesly
H0NDA eu2000i
