RV.Net Open Roads Forum: Fifth-Wheels: Towing with tonneau
 > Towing with tonneau
esfd243
East Syracuse, NY
Posted: 05/03/12 06:07am Link  |  Print  |  Notify Moderator
Does anyone tow a fifth wheel with a tonneau cover on? I have seen some people do this is the tri fold covers open 2/3 of the way. This to me seems that there would not be a way to use the front of the bed between the hitch and the cab. I have also seen the roll up style covers but they just look messy when rolled up. Any suggestions?
Mike, Dawn & Mallori
2011 Keystone Cougar 324RLB (1st 5th wheel)
2012 Chevy 2500 HD D/A 3.73
Bill1374
northern New York
Posted: 05/03/12 06:16am Link  |  Print  |  Notify Moderator
Currently have a roll up that sits nice and tight to the cab. Works good.
Years ago, I had a cover that had a center panel that fit around the hitch. Also had a weather seal that closed the bed up either towing or not. That was great as everything in the truck was out of sight and dry. As far as I know, company is no longer in business as I tried to fnd them.
Bill
2011 Hitchhiker Discover America 345RSE
2006 Dodge quadcab,dually 2 wheel drive
cpski2b
Katy, TX
Posted: 05/03/12 06:19am Link  |  Print  |  Notify Moderator
I have a short Bed F250 with Superglide hitch and have a Bakflip g2 tonneau. I can either use it in it's folded horizontal position, or vertical position depending on what I have in the front of the bed. It can be raised while the trailer is attached also. When it's folded up it's about the height of one of the newer lower profile tool boxes.
http://www.bakfliptonneaucover.com/bakflip_g2
TT: '08 35' Palamino Sabre 5er
Truck: '04 F250 6.0 4wd
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 05/03/12 06:26am Link  |  Print  |  Notify Moderator
I also have a roll up that is very water tight and rolls up tight and neat to the cab. Those that looks messy are not rolled up properly, are cheap covers or the owner just does not care.
Pete_k
Stantonville Tn
Posted: 05/03/12 06:35am Link  |  Print  |  Notify Moderator
Plan on using my retrax roll up bed cover with ours. Leave it opened when towing. But when unhooked just pull it back and everything is out of site and out of mine. Plus will be adding the extra fuel tank under it also.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
DelawareCamper
Newark, Delaware
Posted: 05/03/12 06:40am Link  |  Print  |  Notify Moderator
we have a tri-fold cover and run it when towing. not a problem,,
Mike & Denise
2011 Silverado 3500HD Dually CC 4x4 LT1 D/A
2008 Cedar Creek Silver Back 35L4QB
PullRite 20.5 Super 5th & SuperRails
Cedar Creek 1262DelawareCamper
PICS
boston blacky
Gatineau Quebec Canada
Posted: 05/03/12 06:54am Link  |  Print  |  Notify Moderator
Yes siree, Bob. I had a Pace Edwards Cover on my previous Pick-up. I was o.k. as I could set it (actually roll it) back into a position just in front of my hitch while towing my 5er. The cover on my present truck - is much better for it folds into four parts and rest tightly, locked to a secure spot well in front of my hitch. Don't know the make or model of this cover but it has the markings (Logo) of Dodge RAM - and was installed by my Dodge dealer.
Bottom line keeps the bed and contents 'out of sight and out of mind'.
p.s. That Pace Edwards cover leaked in rain water and rattled while towing. My new one does not. I like it - a lot!!
BOSTON BLK
M GO BLUE
Southgate, MI
Posted: 05/03/12 07:08am Link  |  Print  |  Notify Moderator
x2
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
BB_TX
McKinney, Texas
Posted: 05/03/12 08:04am Link  |  Print  |  Notify Moderator
I have a Pace Edwards Full Metal Jackrabbit roll type tonneau cover on mine. Normally I leave it fully open when towing. But I often put two 26" bikes laying in the bed in front of the hitch. When I do that and if I plan to stop somewhere and be away from the truck, I will roll the top back near the hitch and lock it so the bikes can't walk away. Can also tow with it rolled back near the hitch if I want to keep the bikes (or any thing else) covered and out of sight.
By "messy" I assume you are talking about the soft covers when rolled up.
ependydad
Columbia, MD
Posted: 05/03/12 08:08am Link  |  Print  |  Notify Moderator
RetraxPro cover here. LOVE everything about it.
2013 Sabre 36QBOK
Truck: 2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion hitch
Nights Camped: (2013: 10, 2012: 52, 2011: 28)
Blog about learning to RV, mishaps and adventures
