RV.Net Open Roads Forum: Fifth-Wheels: Towing with tonneau
 > Towing with tonneau
ralphnjoann
Canon City, CO
Posted: 05/03/12 08:15am Link  |  Print  |  Notify Moderator
I have a roll-up. When rolling up to use the 5er, I leave the back rail on, and with DW on one side and me on the other, we roll it up tightly and evenly. It's never been a problem.
mobilcastle
OH
Posted: 05/03/12 08:20am Link  |  Print  |  Notify Moderator
I have a Truxedo Lo Pro Tonneau Cover-check it out you will like it.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
bpounds
Whittier CA
Posted: 05/03/12 08:41am Link  |  Print  |  Notify Moderator
Retrax for me. I roll it back to a couple of inches ahead of the pinbox when towing. Close it and lock it when we unhitch at our destination.
Here is a pic of the Retrax closed over my Vee tail gate.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
skipnchar
Topeka or somewhere else
Posted: 05/03/12 08:45am Link  |  Print  |  Notify Moderator
There are a number of different models that will fold up completely opening the entire bed when folded up and attached over the rear window (Bak Flip is one that comes to mind) and my Extang would easily allow use of the forward third of the bed with the trailer attached. Lots of room to push things under the closed section but not as handy as the ones that fold up completely.
Here's the Back Flip Model
attuco
grand junction
Posted: 05/03/12 08:59am Link  |  Print  |  Notify Moderator
I'm curious now. Don't you guys with covers experience the updraft force that I do? It will just about suck anything out of the bed.
BB_TX
McKinney, Texas
Posted: 05/03/12 09:08am Link  |  Print  |  Notify Moderator
No problem on mine. I am sure something very light would fly out. But I put a ramp for the dog back there. And wood blocks for the front jacks have been left there with no problem.
bpounds
Whittier CA
Posted: 05/03/12 09:21am Link  |  Print  |  Notify Moderator
Sure, but covering part of the bed helps reduce the lift. That's why I leave the cover closed as far as I can and still allow the pinbox to swing. The Vee tail gate helps too.
MO_Trout_Bum
Missouri
Posted: 05/03/12 12:15pm Link  |  Print  |  Notify Moderator
Just installed an Access Lorado rollup cover, which works our very well. Gives full access to entire bed, didn't cost as much as some of the fold-up covers that give full access, and has lifetime guarantee on the tarp. Very good option for $450.
2004 Silverado 2500HD Ext, Duramax LLY, 4WD, 3.73
2012 Keystone Cougar 327RES
Allworth
Orlando, FL
Posted: 05/03/12 12:21pm Link  |  Print  |  Notify Moderator
I have the quad-fold on my long bed (installed by Chevy for the previous owner) and the trailer tows fine with all four pannels stacked in the forward position.
I installed a plywood partition across the bed under the forward hinge line and made the front compartment a lockable storage compartment for grill, chairs, extra power (50A) cord, soft drinks, etc.
By setting the rear pannels up in an inverted "V" under the nose of the trailer, I can open the front compartment while hitched.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
car2900
Mount Juliet, Tennessee
Posted: 05/03/12 12:46pm Link  |  Print  |  Notify Moderator
DelawareCamper wrote:
we have a tri-fold cover and run it when towing. not a problem,,
X2
Also have a tri-fold cover, wouldn't go anywhere without it. I once had a roll up cover that has a rail on each side that stuck up about 1 1/2 inches which lowered the distance from bottom of front of trailer to the rail. Went with the tri-fold, no rail system and much easier to fold back, maybe 5 seconds.
2012 Palomino Sabre 31 RETS-6 (6,000# axles)
2011 Chevy Silverado 2500 HD Duramax/Allison 6.6, 4x4
B&W Patriot 16K
