edsuph
Illinois
I will be going to daughters house and parking in her driveway. What can we safely run when plugged into a 20 amp circuit in her garage? Can we run the air conditioner?
A bad day RVing is better than a good day working.
dougrainer
Carrolton, Texas
NO. You can, but not safely. Remember, the AC unit is NOT the only thing pulling 120 power in an RV. You have the Power Converter or Inverter/Charger whichever you have and you may have the refer on. Doug
padre44
Clarksville, tn
Will probably trip the circuit breaker in the house. Most other stuff will run though.
Eorb
Orlando
I have done that, and it didn't trip. However, I discovered burning around the plug, indicating that it was to much draw. I was using a very heavy duty extension cord. I have since ceased from doing it.
1995brave
San Antonio, TX
If it is a 13.5 air probably, but you will need to run the fridge and water heater off of gas. And no microwave while air is running. No coffee pot or hair dryer either.
Robert78121
San Francisco Bay Area
When visiting my kids I plug into a 20 AMP circuit, and I'm able to run my rear AC at night. It's a slightly smaller unit than the front. I am also able to run my fridge off of electric at the same time, and have never had a problem. It's not dangerous due to the breaker, so there's no harm in trying.
Living full-time in the San Francisco Bay Area
Camper: 2004 Damon Daybreak 3285 WorkHorse 8.1
Toad: 2010 Mini Cooper Clubman S - BlueOx
Toy: 2012 Ninja 650 - Versa Haul VH-SPORT-RO
edsuph
Illinois
Thanks for all the responses...............
past-MIdirector
Michigan
If you don't have a low voltage surge protector then a voltage meter plugged into an outlet can safe a lot of repairs. These meters allow you to check the incoming voltage. As long as the voltage does not drop below 107 volts with the A/C on you're safe to run it. Low voltage from a house outlet due to power draw can damage a lot of electric boards and large appliances in your rig. Be safe, be smart, for around $20 it's inexpensive added safe guard.
TURBODOG1000
INDY
Use a good adapter between your RV cord and heavy duty extention cord, check it from time to time for heat. Use common sense when using the A/C, like keeping the lighting to only whats needed, fridge on gas and water heater on gas.
This should work fine, the weakest link is the cord adapter.
I use a "Kill-a-watt" plug in meter to keep track of my voltage.
Have a nice visit!
edited 05/03/12 07:12am by TURBODOG1000 *
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
OldF**t
Crossville, TN
Shouldn't be any problem. My EMS shows an 11 to 12 amp draw when one a/c (13.5) is running. The only problem you may run into is even though the circuit is rated for 20 amps the outlet itself may only be rated for 15 amps.
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2009 Kymco Xciting 500Ri
1 wife and 7 cats
