We had this happen once. It turned out to be due to the ice maker water valve having frozen in the open position, or something equivalent. All we did was clean up the mess and defrost the unit. It worked fine afterwards.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
If the fridge is off one possibility is the ice maker was full when turned off and the water never froze and splashed out.
We always turn the water off to the icemaker the last night before going home, when even use the icemaker, and that will allow it to run and mostly empty the tray so not much to wipe out later.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
