beemerphile1
I'm 57, I'm not a
LPG tanks are permanently mounted like in a motorhome. LPG DOT cylinders are used on trailers.
I would have to see proof that any tunnel will prohibit an RV with LPG cylinders/tanks. When you see regulations like that it is regarding commercial transportation, it does not apply to private use. There may be limitations on how many pounds/gallons but not an outright ban. What would a MH do? A permanently mounted tank cannot be removed easily.
- Soren Kierkegaard
Atlee
Mechanicsville, VA
beemerphile1 wrote: LPG tanks are permanently mounted like in a motorhome. LPG DOT cylinders are used on trailers.
Go to Maryland DOT. You will see that it is illegal to go through the underwater tunnels there if you have LP tanks or cylinders. Doesn't matter if they are shut off or not. That includes both I-95 and I-895.
Obviously, Baltimore has another way to go north or south other than those two tunnels. Any vehicle, RV or otherwise, that has LP tanks or cylinders can use the Key Bridge on I-695.
In Virginia, an RV can use all the underwater tunnels even if it has LP tanks or cylinders, BUT the gas must be turned off before entering the tunnel.
Erroll, Mary, Duffy the Badger Dog plus "Ollie"
2009 HiLo Towlite 2209T
2005 F150 Supercab 4x4, w/ 5.4L
1996 RoadTrek 210 Popular, on 1995 Chevy Chassis
powderman426
ohio
McDaddy wrote: Skip, I guess I don't understand your statement that trailers don't have LP tanks. I have two 30 lb LP tanks mounted on the front of my travel trailer (on the tongue). Am I missunderstanding?
I believe he meant permantly installed tanks that are not easily removable and/or mot removed for refilling.different regulations on those tanks. JMG
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Chad/Jen
Atlee wrote: Go to Maryland DOT. You will see that it is illegal to go through the underwater tunnels there if you have LP tanks or cylinders. Doesn't matter if they are shut off or not. That includes both I-95 and I-895.
It's been a while since I've been on 95 around that area but we're going that way this summer. Can you help me remember where the tunnels are so I can avoid them?
Thsldo
Massachusetts
this is a good question, I never thought of it, and just drove through the tunnel on my way to NH or ME. Mass Dot has this on their site
http://www.massdot.state.ma.us/highway/DoingBusinessWithUs/PermitsRoadAccessPrograms/CommercialTransport.aspx#hazmat
so would a propane tank be described as hazmat? if so, wouldn't we all need the HC safety sign on the the back of our trailers? I imagine there is a size limit. just something to think about.
Tom & Steph and 4 munchkins
2001 Coachmen Cadet Hybrid
2005 Dodge Durango 5.7
sgip2000
Oregon
Does anyone else think these rules are a bit dumb since there's no limit on how much fuel can be in your fuel tank on the TV or MH?
Is 60 lbs of propane that much more flammable than 100 gals of diesel?
McDaddy
Saugus, Ma
60 lbs of propane is much more flammable than 100 gallons of diesel.
Bonefish
Midland, TX
McDaddy wrote: 60 lbs of propane is much more flammable than 100 gallons of diesel.
60# of propane is 15 gallons. 100 gallons of diesel will burn hotter and do more damage. I have seen several concrete bridges that have been replace due to diesel fires. Not one have I seen due to a propane fire.
Bonefish
mowermech
Billings, MT
It is an issue of terminology. Technically, you do NOT have two 30 lb. LP TANKS on your trailer, you have two 30 lb. BOTTLES or CYLINDERS.
A lot of people think they are TANKS, but they really are not.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
biskit6
Alabama
mowermech wrote: McDaddy wrote: Skip, I guess I don't understand your statement that trailers don't have LP tanks. I have two 30 lb LP tanks mounted on the front of my travel trailer (on the tongue). Am I missunderstanding?
Yeah, but propane is very easy to ignite. Try to light diesel and see how that goes.
2005 Crossroads Zinger ZT18RB
2009 GMC Sierra 1500 4.8L, P3 BC
