RV.Net Open Roads Forum: General RVing Issues: 13k v 15k AC
 > 13k v 15k AC
Playtime II
No. VA
Posted: 05/03/12 08:10am Link  |  Print  |  Notify Moderator
How many Amps does the 15k draw (Start/constant)? I often plug up at the house on a 20Amp house circuit to cool the trailer with my 13k AC while loading/prep/DIY projects.
Playtime IV
2006 HR Scepter 42DSQ
SWD
Land of Living Skies
Posted: 05/03/12 08:29am Link  |  Print  |  Notify Moderator
I know that 20amps is bare minimum for starting and operating a 13.5 AC. I can only imagine that you'll need at least 25-30 amps to get the 15k going. The newer style ones may be able to start on 20 amps. One spot I read, claimed 16amps for a Coleman 15k ac unit.
skipnchar
Topeka or somewhere else
Posted: 05/03/12 08:30am Link  |  Print  |  Notify Moderator
Different brands will draw different amounts of current both starting and running. Should be some info inside of the cover of the AC.
VintageRacer
Dundas, Ontario
Posted: 05/03/12 08:33am Link  |  Print  |  Notify Moderator
If all that is on is the AC, then either one is fine on a 20 amp house circuit. 15K BTU draws around (it varies with make and outside temps) 13A running, and instantaneous surge around twice that when starting. You can sometimes run a 15K AC on a 15 amp breaker, but sometimes they will pop after a while.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
pianotuna
Regina, SK, Canada
Hi,
It very much depends on the design of the unit. For example my old RV had a 13500 air conditioner of the vintage of 2002. It would barely start on a 15 amp circuit. My newer RV the air conditioner is 2004 vintage--and it draws just 960 watts while running, so it easily starts on a 15 amp circuit.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
 > 13k v 15k AC
