RV.Net Open Roads Forum: School me on difference between Rancho's and Bilstein Shocks
 > School me on difference between Rancho's and Bilstein Shocks
Griffon12
Oceanside, CA
Posted: 05/04/12 06:20am Link  |  Print  |  Notify Moderator
I currently have custom valved Fox shocks and have had bilstein 5100's, 5160's, and Ranchos. If you're using your truck mainly for the camper I also suggest the Rancho 9000's, set them high and don't touch the adjustment again once you've found the best ride. The Bilsteins are a better built shock but will not match the Ranchos stiffer valving unless you get custom valved $$$$$$$$$$$ Bilsteins. Plus (I've never used it) I've heard the Rancho warranty is much easier to use if you encounter problems/leaks. I have friends that replace their Rancho steering stabilizer shock under warraty once a year just to have a new one every year.
2005 Ram 2500 R/C 4X4, Hellwig bags, Big Wig, 35" Toyo M/T, Kroeker suspension,Smarty, BD O/D delete
1992 Chevy K3500 4X4, utility bed w/custom 1994 Alaskan C/O
DiscoChicken
Lawrenceville, GA
Posted: 05/04/12 02:48pm Link  |  Print  |  Notify Moderator
I have heard of the adjust knob going bad on Ranchos. I went with the Bilsteins and have been very happy.
Adventurer/Ford
SaltySal
Long Island, NY
Posted: 05/04/12 08:18pm Link  |  Print  |  Notify Moderator
Recently had to get a new truck/camper combo and since I came up with a Lance 1161 I replaced my stock shocks with Rancho RS9000XLs all around. Due to the weight/size of my camper I also installed a Hellwig Bigwig at the same time. While I don't believe the plastic adjustment knobs can corrode, I have found them a little hard to reach and the molded numbers nearly impossible to read (for those over 40). Some suggested turn all the way to left and count clicks to the right to increase pressure. Never heard clicks, can't see anything. Turned it all the way up and left it that way. WOW! Best ride I've ever experienced, especially considering I am floating a 20'x 11-12' 2.5+ ton payload. However, Ranchos on 9 without the payload is the worst ride I've ever experienced. Can't be bothered anymore with this manual adjustment and broke down and purchased the "MyRide" Digital Remote Control for $150. Will comment further after install.
2003 DODGE 3500 QC Laramie 4X4 DRW HO5.9L CTD Hellwig BigWig Rancho RS9000XLs, LoadStops WARN Powerplant 12K LB Bodiak Mounted Winch "ROLLING THUNDER"
2003 LANCE 1161 Torklifts/Fast Guns Super Hitch Solar 2.5kw Genset A/C Leather Int LCDTV "LANCE ROMANCE"
pezvela
San Carlos, Sonora, Mexico
Posted: 05/04/12 08:34pm Link  |  Print  |  Notify Moderator
On the adjustment reading problems, all I did was take a paint pen and highlight the numbers by touching them with the paint pen on the raised letters. It's lasted a year so far, but I do a lot of dry driving.
tilemantim
Santa Rosa,Ca
Posted: 05/04/12 11:49pm Link  |  Print  |  Notify Moderator
You can get the Rancho My Ride system and control your shock settings with w wireless remote.
Desert1667
MD
Posted: 05/05/12 11:11am Link  |  Print  |  Notify Moderator
Thanks for all who replied. I think for ME and my current setup I will go with the Rancho's. There is a nice Rebate until June 30 on the purchase and my truck will only be used for the Lance so ride concerns empty is not a problem.
Michael
Mello Mike
Mesa, AZ
Posted: 05/05/12 11:34am Link  |  Print  |  Notify Moderator
Michael
The reason you gave is exactly why a non-adjustable shock like the Bilstein will work better for your rig.
The rebate on the Rancho 9000's is nice, though.
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
Desert1667
MD
Posted: 05/05/12 01:58pm Link  |  Print  |  Notify Moderator
I did consider that, but a $100.00 rebate is too good to pass up...
Michael
