RV.Net Open Roads Forum: Class A Motorhomes: Day Night Shades
 > Day Night Shades
poisonivy
ky
Posted: 05/03/12 10:19am Link  |  Print  |  Notify Moderator
Have a String broken on the daynight shades. Are there any way to replace one broken string?
LVJ58
Las Vegas, Nevada
Posted: 05/03/12 10:23am Link  |  Print  |  Notify Moderator
When ours break, we've been replacing them with mini-blinds special ordered from Lowe's. So far works great...
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
HappyKayakers
Black River Falls WI
Posted: 05/03/12 10:31am Link  |  Print  |  Notify Moderator
It's about the same amount of work whether you replace one or all strings in a shade. Check here for materials and instructions.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
mockturtle
WA
Posted: 05/03/12 04:35pm Link  |  Print  |  Notify Moderator
Yikes! Is there any way to just replace the blind?
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
bamcote
KsMeMoTn
Or here....The Dirty Blind Man
DH, DW, Bahbutt the Siamese, Molly the Maine Coon
and Mina the rescue mutt
miss you Crystal and Mocha
2008 Fleetwood Bounder 36Z
2007 Saturn Vue AWD with Ready Brake Brute
sowego
northwestern corner of the Nebraska panhandle
Posted: 05/03/12 08:11pm Link  |  Print  |  Notify Moderator
You can restring yourself or there are many companies that clean and restring them. Of course you can buy new shades but if all that is wrong with them is a broken string it is far cheaper to have them restrung.
I'd suggest replacing all the strings on a blind, not just the one that broke or you'll be redoing it later and use a higher quality/thicker string to last longer.
The next best option, one that many people are doing and manufacturers have done...put up a different type of shade. Many switched to MCD then they moved on to another kind. I figure it's a fad thing--at one time many had mini blinds and roller shades then came the day/nights then back to roller shades. Who knows what will be the next one they will come up with.
Myself...I'm going to replace the shades in ours with 2 layers of curtains that can more easily be washed and most certainly easier to replace.
2002 Tiffin Phaeton
2005 Malibu Maxx toad
Jackha1949
Any Where USA
Posted: 05/03/12 09:47pm Link  |  Print  |  Notify Moderator
Try going to fixmyblinds.com, you can buy the right string there and get instructions as well. I agree with others it is just as easy to replace all the strings instead of just one. Good Luck!
Jack & Peg
USN Ret AGC
K1ZMB
Sioux Falls, SD
06 Itasca Horizon 40KD
fcooper
Richmond Hill, Georgia
Posted: 05/03/12 08:15pm Link  |  Print  |  Notify Moderator
If you restring yourself, you'll have to work to get the broken string replaced. Once that is done, replace the unbroken strings one at a time by tying a light weight fishing line to the old string, pull the fishing line through, tie the new string to the fishing line, and then pull the new line through using the fishing line. If you tie the new line to the old line, the knot is too large to go through all of the openings.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
SCVJeff
Santa Clarita, CA.
Posted: 05/04/12 02:47am Link  |  Print  |  Notify Moderator
It may look daunting, but once you get in there and see whats going on it ain't no big deal. It sure wasn't assembled by "skilled" workers because 1/2 of the internal issues are lousy assembly. Just fixed the biggest shade in the coach, and now carry all the string and pieces to repair anything when needed.
Jeff - WA6EQU
jerseyjim
New Jersey
Posted: 05/04/12 04:30am Link  |  Print  |  Notify Moderator
When my mh was new, within the first year, all the strings on all 4 blinds broke. Dealer fixed, no problem. When I inquired about having this done after the warranty, I was told: 1 hour labor. That = 100 bucks. OUCH!
So...removed the day/nites (for measurements) and off to "Blinds To Go" and had the day/nite shades replaced by plastic mini-blinds....$130. Bit of a hassle getting to some of the mounting blocks (really tight spacing), but in the end....no further problems. The mini-blinds fit perfectly, and was able to use the lower anchors from the day/nite shades.
 > Day Night Shades
