mister_d
Southeast, MI - hardly qualified to be a
Update: I'm worried about unhooking. I had almost no tension on the hitch and everything was unhooked. When I went to pull away the whole TT shook a bit. It wasn't a big deal but I'm worried when I'm on a very uneven campsite. Is this normal?
I'm trying to plan my installation of the HA I purchased off craigslist.
1. How long should I plan on the install taking? (took my sweet time - almost 6 hours - semi-entertaining kids concurrently)
2. Do most people have to move their propane tanks? (I had to ... along with my trailer disconnect wire)
3. Should I just assume I'll need the chain and cord extensions? (electric is fine but my chains are short - can I just buy chain and link connectors at Home Depot?)
4. Should I buy the Hitch Helper? (still thinking about this - we camp at a lot of state parks which aren't usually a straight shot)
edited 05/05/12 10:35pm by mister_d *
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
dalenoel
S.E. Michigan
1. If you know the hitch real well it might be 2 - 3 hours for the install. Do it at home or on level ground
2. Yes propane tanks move or sometimes the battery box needs to move. This took the most time.
3. Assume only one chain extension if you redo the existing chain. I can explain how. Some of the new Hensley boxes have the cord extension in the box.
4. I don't use the Hitch Helper but if you want one then I can sell you mine that has not been used at all.
Since you are in SE Mich then PM me and maybe I can help you with the install. Did one a couple of weeks ago for a friend.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
mister_d
Thanks everyone. I will have to move the TT to the street to work on it so I wanted to make sure I left myself ample time and was prepared.
taborekle
Clements, Md
mister_d wrote: I'm trying to plan my installation of the HA I purchased off craigslist.
2 or 3 hours to install.
You should not have to move your propane tanks
You will probably need chain and cord extensions.
You should buy the hitch helper as I've found that very useful.
Hope that helps,
Larry
mikeb9550
MI
Couple of hours like others have said.
Didnt have to move the LP tanks on old trailer but did on the current one
Needed chain extensions but no plug extensions on either trailer
I use to have a hitch helper. They are ok. I dont have or use it anymore
Mike
2006 Ford E350 Van (standard length)
V10, 3.73, 5 Star Tuner, Hellwig Rear Sway Bar, Prodigy BC, Hensley Arrow Hitch
2006 Jayco Jay Flight 26BHS
Gman22
Burlington, Ontario
1. How long should I plan on the install taking? 3 hours
2. Do most people have to move their propane tanks? Not in my experience
3. Should I just assume I'll need the chain and cord extensions? No, do install first, then size any extensions if needed
4. Should I buy the Hitch Helper? No
2000 Coleman Bayside
2006 Ford Expedition Ltd. 5.4 L/3.73
camp-n-family
Canada
1. Installed mine in 2 hours. Fairly straight forward. Did my buddies next in less than 2hrs.
2. Every trailer is different with regards to propane and battery placement. Didn't have to move either of mine, buddy had to move both.
3. You'll likely need the chain extenders and plug unless yours are exceptionally long.
4. Had a hitchhiker, never used it so I sold it. The head of the Hensley is moveable left/right/up/down etc so if you're not lined straight up it's not a big deal. Just shift the head, it's easier than a conventional hitch.
'07 Toyota Tundra Crewmax Limited
'06 Forest River Flagstaff 26BH(sold)
'13 Keystone Bullet Premier 31BHPR
Hitched by Hensley, Viewed by McKesh
mister_d
check my OP - updated it
Ranger431
Knoxville, TN
If it doesn't want to let go, adjust your WD struts a little bit. It is most likely that there is a little binding between the hitch and the coupler. It's happened to me a couple times.
2012 Jayco 32TSBH
2004 Ford Excursion
ProPride 3P Hitch
Tru Control brake controller
Roadmaster Active Suspension
