sunline1
Northeastern Pa
Is there a spring or something to replace to bring back the seat belt retractor ?
Mine seams to have gotten a little lazy, does sem to retract all the way all the time. Then it gets caught in the door latch assm when I close the door.
Have a 97 chev regular cab k2500 chevy pickup.
any thoughts etc appreciated.
thanks
Sunline1
B.O. Plenty
Minnesota
If I remember right they used to have a feature on some of the belts that would lock them when they were partially out for use with a child seat. You then have to pull them all the way out to get them to release and wind back up. Maybe someone else can chime in on this.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
geneo2004
Pleasant Grove Utah
Seat belts wear out and you might price some at the wrecking yard as I am sure they are the same for many years. I am not sure what year they started the sensor and locking when in a collision. Don't go there. Good luck finding this great safety device.
sunline1
Northeastern Pa
Maybe i wasn't real clear in the OP.
The seat belt (Driver side) works fine while while driving the truck. When I release it, get out of the truck, then try to close the door, it doesn't retract all the way and sometimes gets stuck in the door latch. In other words I close the door on the belt or the part that inserts into the hold point.
Sunline1
ib516
Up here!
It's possible that the mechanism is "gummed up" with fuzz/lint, and that is causing the belt not to retract properly. Try taking the interior trim off and cleaning it (compressed air?) and lubing the moving parts before replacing it.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Perrysburg Dodgeboy
Perrysburg, Ohio USA
You (the seat belt) have reached the end of it's life and is time to replace it. They can not be rebuilt. Pick up a new one from the dealer or buy one from a wrecking yard.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
buzzard616
Medicine Hat, Ab, Canada
I've never had a new vehicle in my life. 'Shoving' the seat belt up into the slot in the post when you release it will become automatic over time. The retract spring is just tired and needs a hand.
Stu
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
sunline1
Northeastern Pa
Thanks all for your input.
Just for the heck of it I'm going to take off the cover if I can figure it out, and blow it out as suggested.
Sunline1
sljkansas
Miami Co. Kansas
If memory servers me right, at the botom of the belt, there is a bar that moves wo lock the belt in place. if they get alot of dust/drit, soda spills on them they can gum up and not work correctly. A goot cleaning may help it.
edited 05/04/12 07:37am by sljkansas *
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
sunline1
Northeastern Pa
Just went out to look at taking the cover off.
Pulled the belt all the wayout and "Part" way out I see that the belt was twisted some, the edge partially folded over on the center section of the belt.
Took the twist/overlap out and it seams to retract much better, think I'l give it a try.
Sunline1
