RV.Net Open Roads Forum: Chain links on Reese Dual cam look to be pulling apart
Search only in Towing
Open Roads Forum  >  Towing
 > Chain links on Reese Dual cam look to be pulling apart
subversive
Alberta
Posted: 05/03/12 01:12pm Link  |  Print  |  Notify Moderator
Hi, I noticed while de-winterizing my trailer that the links on the Reese chains look like they are pulling apart. Pictures below (assuming I can make it work right), thoughts? Should I just replace the chains, or have them re-welded, or something else?
Mike & Melynda joined by rugrats Alexandra, Zoe, and Georgia
2010 Yukon XL 3/4 ton V8
2011 North Trail 32QBSS, Reese Dual Cam
Our trailer and camping pics
BarneyS
S.E. Lower Michigan
Posted: 05/03/12 01:15pm Link  |  Print  |  Notify Moderator
I would send the picture and an e-mail to Reese. They will probably replace it for nothing. Contact Reese
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
301TBS
Ontario, Canada
Posted: 05/03/12 01:21pm Link  |  Print  |  Notify Moderator
Good work noticing that? Could be a disaster waiting to happen. Definately don't weld it.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
BenK
SF BayArea
Posted: 05/03/12 01:37pm Link  |  Print  |  Notify Moderator
Ditto contacting Reese...there might be a recall.
Note that I don't think Reese makes chains and has purchased it from some supplier
Looks like electrical welded and that either the mating surfaces were not clean
enough, touching (flatness) enough and/or not enough amperes (and long enough)
Hope their supplier has their stock segregated by vendor and lot numbers
-Ben Picture of my rig
downtheroad
Pacific Northwest
Posted: 05/03/12 02:01pm Link  |  Print  |  Notify Moderator
Wow...I'll be checking mine from time to time after seeing this...
Yes, contact Reese and PLEASE let us know what they have to say by adding to this thread...
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Jerry9n
SE Michigan
Posted: 05/03/12 05:34pm Link  |  Print  |  Notify Moderator
Is that the link that is on the "hook"? If so from the picture, you have the remaining loose end link between the hook and the link that is hooked over the hook. By rights it should be dangling free below the hook. My guess is, that if that is the link that is separating, is that the link that is wedged in there is putting a lot of pressure on the side of the weld. With it dangling free, most of the load is straight in tension. It is probably a marginal weld and the link wedged there didn't help.
Hope that is clear. I don't have one of these hitches, but any time in industry we used chains we made sure the loose end was "free" and not bound at the top of the loaded link.
Sorry if that is confusing.
JU
301TBS
Ontario, Canada
Posted: 05/03/12 05:42pm Link  |  Print  |  Notify Moderator
The bars are not on in the picture, i think the chain is hooked on for storage, keeping it off the ground.
Need-A-Vacation
Mi
Posted: 05/03/12 06:47pm Link  |  Print  |  Notify Moderator
+1!!!!!! Holy cripe, good eyes!!!!
Are all the links that way, or just the 1?
Thank you for posting that as I wouldn't have thought to check the links.
Good luck when you talk to Reese, and please keep us posted!
Chris
jerem0621
Sequatchie, TN
Posted: 05/03/12 07:12pm Link  |  Print  |  Notify Moderator
Reese has always been a pleasure to deal with in my experience. Hopefully they will resolve this for you quickly.
Thanks!
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
JBarca
Dublin, Ohio, USA
Posted: 05/03/12 08:15pm Link  |  Print  |  Notify Moderator
The chain needs to be replaced.
Call Reese, they have a lifetime warranty on the hitch.
The loads of the WD hitch should not be any where near the strength of that chain. I do not see that as a sizing problem but a manufacturing defect. They will stand behind it.
And, good for you for inspecting and looking!! Any machine made needs inspection on some periodic basis.
Let us know how you make out
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
