RV.Net Open Roads Forum: Class A Motorhomes: How to Remove TV from Motorhome
 > How to Remove TV from Motorhome
RVtrader
Reseda
Posted: 05/03/12 01:34pm Link  |  Print  |  Notify Moderator
I have a 2005 38J Adventure we never use the TV and want to make a extra storage has anyone done this?
I removed the under panel of the cabinet but there are no screws under bottom panel for the TV so i can remove it.
need help.
Thanks
paulcardoza
Southeastern Massachusetts
Posted: 05/03/12 01:38pm Link  |  Print  |  Notify Moderator
There should be a cabinet trim faceplate which you remove from around the front of the TV. You may have wooden screw cover plugs to remove. Behind that, there should be mounting brackets visible which secure the TV to the top and bottom of the cabinet, which you also must remove. Then, be careful as those old CRT TV's are darned heavy!!!!!!!
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
mike brez
milford ct
Posted: 05/03/12 02:58pm Link  |  Print  |  Notify Moderator
All you should need is a BFH
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
Escargot
California
Posted: 05/03/12 05:12pm Link  |  Print  |  Notify Moderator
X2
2003 PleasureWay Excel TD, Dodge chassis
bsinmich
Holland, MI
Posted: 05/03/12 05:20pm Link  |  Print  |  Notify Moderator
I know a ouple of places you could park in Detroit and they would remove the TV and a lot of other things also, for free.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Trackrig
Anchorage, Alaska until June, 2013
Posted: 05/03/12 08:46pm Link  |  Print  |  Notify Moderator
If you go to YouTube and type a search for REPLACE RV (OR MOTORHOME) TV, it will bring up several videos that start with how to remove the old TV.
Bill
Kiwi_too
Western, WA
Posted: 05/03/12 08:53pm Link  |  Print  |  Notify Moderator
There is a good chance that you have a strap over the back area to prevent it from rocking forward.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
LVJ58
Las Vegas, Nevada
Posted: 05/03/12 09:57pm Link  |  Print  |  Notify Moderator
If all else fails, I would contact the Winnebago factory, since they put it together, they should be able to help you.
Good luck and safe travels
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
W4MBG
Williamsburg, VA
Posted: 05/04/12 09:14am Link  |  Print  |  Notify Moderator
two years ago the title of this thread would have sounded quite normal. now my first thought was "how did he get his Tow Vehicle in his motorhome in the first place?"
RVs have taken over my mind!
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
RVtrader
Reseda
Posted: 05/04/12 10:08am Link  |  Print  |  Notify Moderator
Update
I did find 2 screws that hold down a metal strap but you won't know this tell after you remove the TV also what looks like a speaker grill in the upper right side of the cabinet
is an air hole you can fit a small hand which in my case was my wife had to put her hand in and push on the back of the TV then i was able to pull it out.
Thanks for your help.
